MikroTik RouterOS version 5.0beta3 released!
What’s new in 5.0beta3 (2010-Jun-17 13:46):
*) hotspot - drop hotspot specific tcp connections from non-hotspot clients
already at firewall;
*) lcd - added support for AX89063
*) console - output of ‘/ping’ and ‘/tool traceroute’ commands is more
in line with the rest of the console commands;
*) api - ‘/ping’ and ‘/tool traceroute’ commands are fully functional;
*) console - added ‘server’ and ‘server-port’ arguments to ‘/resolve’ command;
*) lcd - show free/total memory in units of million bytes (MB);
*) lcd - added page that shows system identity;
*) sstp - made it work with Windows 7;
*) sstp server - client reconnects did not work;
*) winbox - implemented proper maximize support for inner windows;
*) fix 5&10MHz channel support for 11n cards;
*) added IRQ balancer;
*) enabled PCI MSI on i386 multicore setups;
http://www.mikrotik.com/download/routeros-ALL-5.0beta3.torrent
Important note!
Latest beta release 5.0beta3 have initial support for two features,
  1. IRQ balancing - allow IRQ assignation of to a specific CPU
  2. PCI MSI support - allows to avoid most situation when several physical interfaces are with same IRQ
    Bottom line - with these 2 features you will be able to assign specific physical interface to specific CPU core.
IRQ balancer can be found in “/system resources irq” menu.
Specifying ranges of confederation-peers under bgp-instances is broken in winbox.
/ routing bgp instance set 0 confederation-peers=65510-65520
works from cli but not from winbox.
Also making any change on bgp-instance window in winbox causes configuration entered in cli to be lost.
OoOo
Cool a new beta…
Loaded on a 450G and 750G.. No new issues… All is well..
N connection that was running nice at 20mb/s tcp is now not doing so well. Also a snmp voltage query is now failing on 411AH…
I’ve upgraded RB750 from v4.10 to v5.0beta3.
Router doesn’t boot. How can I restore it???
WOOOOOOOOOOOAAAAAA YEAAAAHHHH !!! THATS THE STUFFFF !!!
Temperature reading via snmp on RB800 still doesnt workning…now i getting “No Such Name” value as respond..
Take the new RouterOS MIB file and use it with SNMP-walk, you will see the value. There is no name, because there isn’t supposed to be a name.
Ooooo Thakns, i´ve installed oid to PRTG and works fine!!!
Excuse me, I can’t download this file. (http://download.mikrotik.com/all_packages-mipsbe-5.0beta3.zip)
Err Msg:
2010-06-18 16:50:08 Connecting download.mikrotik.com:80
2010-06-18 16:50:08 Connected
2010-06-18 16:50:08 GET /all_packages-mipsbe-5.0beta3.zip HTTP/1.0
2010-06-18 16:50:08 Host: download.mikrotik.com
2010-06-18 16:50:08 Referer: http://www.mikrotik.com/download.html
2010-06-18 16:50:08 User-Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.1; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; InfoPath.2; OfficeLiveConnector.1.5; OfficeLivePatch.1.3)
2010-06-18 16:50:08 Accept: /
2010-06-18 16:50:08 Pragma: no-cache
2010-06-18 16:50:08 Cache-Control: no-cache
2010-06-18 16:50:08 Connection: close
2010-06-18 16:50:08 HTTP/1.0 403 Forbidden
2010-06-18 16:50:08 Content-Type: text/html
2010-06-18 16:50:08 Content-Length: 345
2010-06-18 16:50:08 Date: Fri, 18 Jun 2010 08:50:10 GMT
2010-06-18 16:50:08 Server: lighttpd/1.4.22
2010-06-18 16:50:08 Wait for retry(5S)
You are right, we will fix it in a moment.
ros with renos inside???
take a look at this pic.
the torent was locked by antivirus software…
choose better antivirus software :smiley:
after upgrading to 5.03beta3 routerboards are not booting… any idea?
which routerboard model you have, and show us what you see on the console output?
it was rb600 and rb333. eth link is flapping and nothing on console port,also no “beep” when power is up
Sounds like exactly the problem I had with a RB230. Completely trashed the boot - no beeps, nothing on the console. Even a netinstall didn’t work - it downloaded the files and then just hung. The only way I could resolve it was to take the CF out and do a NetInstall directly to that. Then I had to contact MT and arrange for a new licence since the softID had changed. Having spent a good three hours trying to solve it, I came to the opinion that I was lucky the RB230 boots from CF and that I could remove it. Had it been, say, a RB750, it would have been completely bricked.
I guess its a good thing that jtag unbricking exists :wink:
After the collapse of the direct closure of Figure Click winbox
I have just tested that with v5 b 3 the Drivers page is .. a window to another dimension :stuck_out_tongue: an alien dimension :stuck_out_tongue: so it can’t be seen. So the ordinary peasent will see it as a funky distortion of the screen. Only those with blue blood will se the aliens waving at him :slight_smile:
