Dear all,
I am not able to determine why my Mikrotik box shows only a single line of log information.
I have check all config and it looks fine.
I am experiencing this issue in RB3011 and hEX routers.
Best regards,
Sanay
Dear all,
Best regards,
Sanay
Go to terminal and enter
/system logging action export
Post result here.
Thank for your reply.
Please find the output below:
/system logging action> export
set 0 memory-lines=1
set 1 disk-file-name=log
Execute this to revert to default config:
set 0 memory-lines=1000
A single log entry may indicate that your router has been compromised somehow. Are you sure you have changed you passwords after upgrading and have you checked your configuration for other problems, e.g. unknown firewall rules or socks proxy settings?
