MikroTik Simple Queue Bandwidth Shaping Limitation
How much traffic can MikroTik manage using Simple Queue, and what is the maximum bandwidth that should be shaped?
I think that the answer for both of your questions is the CPU, the CPU does the traffic shaping.
Stronger CPU = more bandwith/throughput that can be shaped.
I know when i used CAKE when i was pushing gigabit through the line on an rb5009Upr, with limits set to 950/450 (1000/500 fiber line), my cpu usage was 40-45-50%
TLDR; depends what model of router you're using for the simple queue/traffic shaping.
What is the maximum bandwidth that can be shaped per Simple Queue on the MikroTik CCR2116-12G-4S+ and CCR1036-8G-2S+ routers?
I think that it depends on a trafic style, the bigger packets, the less CPU work so the throughput higher. Smaller packets would give lower results at the same CPU's efforts.
There is no single maximum Gbps per Simple Queue for either the CCR2116 or CCR1036. It depends on RouterOS version, queue type and count, packet rate, and CPU headroom.
For a useful capacity number, test the intended queue configuration with representative bidirectional traffic, including small packets. As you raise the load, watch per-core CPU, queue counters, latency and drops. Also verify the test traffic actually reaches the Simple Queue: FastTrack bypasses Simple Queues, so a FastTracked test can look fast while shaping is not being applied.
If you share the RouterOS version, queue count/type, expected Gbps and packet rate, that would make a model-specific estimate much more meaningful.
