Mikrotik Station wds and Ap bridge not working
Hi, We have following setup.
Omnitik - working as ap brdige, connected to LAN
At client end RB711hn, which we want to setup as staion-wds.
It works if we setup as bridge but doesnt work if we setup station-wds.
0 name="wlan1-gateway" mtu=1500 mac-address=00:0C:42:F1:DB:D3 arp=enabled
disable-running-check=no interface-type=Atheros 11N
radio-name="TESTCLIENT" mode=station-wds ssid="singh8028" area=""
frequency-mode=superchannel country=no_country_set antenna-gain=0
frequency=5350 band=5ghz-a/n channel-width=20/40mhz-ht-above
scan-list=default wireless-protocol=any rate-set=default
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-a/g=6Mbps max-station-count=2007 distance=dynamic
tx-power-mode=default noise-floor-threshold=default
nv2-noise-floor-offset=default periodic-calibration=default
periodic-calibration-interval=60 dfs-mode=none wds-mode=dynamic
wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=yes update-stats-interval=disabled bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
wmm-support=disabled hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no
station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0
ht-guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,
mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,
mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
ht-txchains=0 ht-rxchains=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192
tdma-period-size=2 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30
nv2-security=disabled nv2-preshared-key="" hw-retries=7
frame-lifetime=0 adaptive-noise-immunity=none
hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 frequency-offset=0 rate-selection=advanced
multicast-helper=default
AP BRIDGE
Below is configuration...
[admin@AP-BRIDGE] > interface wireless print advanced
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:CD:CE:D1 arp=enabled
radio-name="AP-BRIDGE" mode=ap-bridge ssid="singh8028" area=""
frequency=5350 band=5ghz-a/n channel-width=20mhz scan-list=default
54Mbps
wmm-support=disabled hide-ssid=yes security-profile=default
ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8192
ht-amsdu-threshold=8192 tdma-period-size=2 nv2-queue-count=2
nv2-qos=default nv2-cell-radius=30 nv2-security=disabled
nv2-preshared-key="" hw-retries=7 frame-lifetime=0
adaptive-noise-immunity=none hw-fragmentation-threshold=disabled
hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0
rate-selection=advanced multicast-helper=default
your config is ok, i use this and work fine but only on point to point i never test on multipoint.
on station-bridge works fine too and on many times work better than wds mode.
But When I select station-wds OR station-brdige, it keep searching network doesnt connect to any one
the frecuency 5350 is not stantard channel and on your scan-list of client cpe are by default, you must put the 5350 frecuency on scan-list and try.
Yes.. its resoved, I added freqeuncies like
/interface wireless set wlan1 scan-list=5350.5500,6000
It worked. great thanx.
But can you tell me how do I enable nstream and will it be useful? I have 7 CPEs connecting to AP-Bridge
Nstreme is a Mikrotik propietary funtion, yours cpes must be are Mikrotik too for use tihs protocol.
Nstreme let reach more trougtput, reduce the ping times request, i always use this protocols and is the reason for i use mikrotik.
on AP
Nstreme=enable
framer-police=best fit
on cpe put only
Nstreme=enable
for multipoint miktoik have the nv2 and is a mikrotik propietary too, this is a TDMA protocol an is do think on point to multipoint conetions.
