Mikrotik support please have a look!
https://www.reddit.com/r/mikrotik/comments/1bga27i/problems_getting_netbox_5_ax_to_work/
To start with:
https://mikrotik.com/support
Next, stick to a single topic:
http://forum.mikrotik.com/t/worst-performance-of-netbox-5ax-is-there-any-user-who-uses-this-netbox-5ax/179537/1
Or as someone on Reddit put it: “This device is not intended for the average user, so don’t blame the hardware if you have trouble getting it to work. If you’re unable to configure it properly, consider buying a consumer-friendly equipment instead.
ChatGPT v4 says my config is fine so it’s your fault Mikrotik blah blah :smiley:
My chatGPT uses brainwaves, talking is so yesterday.
