I recently upgraded my network and re-used my mikrotik crs310-8g+2s+in in the new network.
The problem i am seeing is that the switch disconnects from the router roughly every 20 minutes.
When this happens my desktop computer lose the connection to internet for a few seconds.
In Unifi site manager, in the client logs, i can see the switch disconnected messages.
The topology looks like this:
Modem > Ubiquiti UDM Pro max > 10m DAC (Ubiquiti UACC-AOC-SFP10-10M) > Mikrotik crs310-8g+2s+in
Connected to the switch is these devices:
Ubiquiti U7 Pro AP
My desktop computer
I am running routerOS 7.15.2
Firmware on the routerboard is the latest available, 7.15.2
What i have done is i reset the switch, made a basic configuration, disabled RSTP and Fast forward on the bridge interface.
Here is the current config on the switch:
# 2024-07-21 19:58:55 by RouterOS 7.15.2
# software id = xxxx-xxxx
# model = CRS310-8G+2S+
# serial number = xxxxxxxxxxx
add admin-mac=78:9A:18:42:FB:45 auto-mac=no comment=defconf fast-forward=no name=bridge protocol-mode=none
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=sfp-sfpplus2
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip cloud
set update-time=no
/ip dhcp-client
add interface=bridge
/ip hotspot profile
/system clock
set time-zone-name=Europe/Prague
/system note
set show-at-login=no
/system routerboard settings
set boot-os=router-os
/system swos
set address-acquisition-mode=dhcp-only identity="Mikrotik Switch"
Yes there is 1 entry,
07-21 23:44:38 interface,info ether2 link down
07-21 23:44:39 interface,info ether2 link up (speed 10M, full duplex)
ether2 is connected to my desktop.
In the unifi logs there were no disconnects of anything on my network at or around that time.
Looking into this more i can see that during the night there were no disconnects in the Unifi logs.
My desktop was turned off at the time.
At the various times the switch was reported as disconnected, there is nothing in the mikrotik logs around that time that could explain this.
This likely means that your desktop put its NIC into WoL state … which is normally lowest speed possible (10Mbps for ethernet seems to be the norm) to save some energy.
So you’re saying that CRS doesn’t notice disconnects, but router does? I’d expect both ends to report similar behaviour if it was L1/L2 problem (on ethernet level). It may well be that Unifi DAC is not entirely compatible with CRS … MT devices are quite notorious for their iffy support for SFP/SFP+ modules, specially so for 3rd party ones (and DAC does somehow resemble SFP/SFP+ module).
I was originally running 2 mikrotik S+RJ10 modules and a cat7 cable.
But the modules heated up to almost 90celsius so i changed it out for the Ubiquity cable.
I also tested with bypassing SPF+ on the switch and ran the ethernet into one of the 2.5gbit ports.
So UDM pro max via SPF+ S+RJ10 > Cat7 cable 10m > Switch 2.5Gbit port.
But the problem persists no matter what i do.
I thought it could be power saving, so i turned that off on the NIC in device manager.
Not sure if there is another setting somewhere.
Yes the router notice the disconnect but the switch does not.
You using AOC cable not DAC cable. AOC cable has problem with interop. between vendors.
Use optical cable with SFP+ modul ( check the “MSA compliant” certified - will work ).
I had the same problem using Mikrotik S+RJ10 modules.
But it is more stable now after i started using the AOC.
I will leave it as is until i can replace the switch.
