Would just like to throw in my 2 cents here, we would swap out all of our cisco switches if there was a 24 port mikrotik solution in a heart beat. So please do
I also think that RB250GS is a good product, however after using it for some time, I miss some features that other similar switches have. Forgive me, if it seemed that I don’t like your switch offering, this is not the case. I would also like to see a MikroTik switch with more ports, and advanced features.
I am curious what feature omally01 would use, that is not available in her/his current switch.
@Normis
I think it is a perfectly reasonable question to be asking - on any forum. Why would someone swap out existing working product? Is there some compelling Feature? Reliability? Compatibility?
@congo
I read omally01’s post 1 month ago and thought the same thing!
RB250GS but more ports. 8,16,24 giga ethernet + 1-2 SFP slots and all ports included poe injector in 1U rack case with external power on cable terminal.
maybe do two devices. First devices without the SFP but with PoE. Second devices with SFP without POE.
The first device for use in power routerboard antennas.
The second device for use FTTB. Optical fiber uplink to a block of flats and Ethernet customers.
But not less than 16 ports and built on the RB250. None RouterOS. Only SWOS for VLANs. Only L2 switch.
You might be able to swap 1 Cisco for 100 RB switches, but in the end if they lack a VERY basic functionality that this Cisco switch has, then you will have 100 useless switches.
For us I believe this would be completely necessary, if it is PoE and it isn’t 802.3af then they will never be successful in smb->corporate. Along with this they would need to support 802.1p.
CLI would be very handy, either that or a way to quickly manage port configuration via the gui. 24-48 port switches need a method to mass change port configuration with ease otherwise it is too tedious (something like /interface ethernet range ether1-48) and also SFP/SFP+
For the datacenter/server space we’d be looking at some basic L3 routing and also 10 GbE interfaces as this is becoming more commonplace.
I wish MikroTik did in fact have a modular switch with 24, or 48 ports. Cat6 and SFP modules would be nice. If it had an interface range group command, that would be very beneficial, for fast configurations. I like the GUI on the routers, but it would be nice if there was a way to turn off the GUI. To reduce the CPU load on a switch.
