I reaaaly need your help!!
I have a problem with linking 2 mikrotik SXT 5HnD. The situation is the following:
I have to SXTs on 5,17km distance. I get a signal of -74. I did the math:
FSL (Free Space Lost) = -92.4 - 20logR - 20logF + antenna gain (16) + power (25dBm) = -63dBm
According to my calculations theoretically I can get to -63 signal. In practice I have really wide open space and no other antennas on 5Ghz. So I need some info how I can get better signal.
Does the SXT sends the signal on both polarizations by default?
Does the SXT (when I select automatically for TX power) will adjust it to 25 dBm?
How can I increase my signal. I think its my lack of experience with wireless mikrotiks that I cannot get a better signal. I am 98% sure that the Aligment is great, cause I’ve tried it so many times, with so many different vertical and horizontal aligments.
Some people (myself included) have had stability issues when enabling both extension channels and both chains. I highly recommend upgrading to RouterOS 5.4 before starting, as it seems to have cleared up several of these issues with the SXT.
A fair word of warning, if you set up the link using NV2, you will initially see a very poor reading for CCQ and data rate. The readings do not become accurate until you push some bandwidth over the connection for a bit.
If that doesn’t take care of it, post your signal strenghts and wireless config and we will see what else might be going on.
48-121,7= -73,7db(+/-5,5db) for mcs15 20Mhz channel and -74.7(+/-5,5db) for mcs15 40Mhz channel
for mcs0 20Mhz you should have signal=-67,7 (+/- 5,5dB)
The 5,5db variation comes from the antenna precision (+/-2db per each, so it can vary 4db in your link), and it´s not shown on the data-sheet, but the max tx-power can be +/- 1,5db on standard products, and this one should be the same.
In mikrotik, please go to “/interface wireless wlan0 current tx-power” and see how much db you have for each modulation scheme.
I’ve tried to the lowest loss as I can and I did manage to have an -71 signal. Still it wasn’t enough for roughly 100Mbps TCP bandwidth. I manage to put around 45-55Mbps U+D through the link. Anyways, I will need another equipment I guess.
I was wondering for your practical works with Mikrotik SXT, what is the longest distance that you’ve achieved and how many Mbps have you put through that link?
