MikroTik SXT 5HPnD
Dear frnds,
My MikroTik SXT 5HPnD is automatically resetting to factory default while restarting. it is not saving the configuration. please advise the solution.
Check this post first:
http://forum.mikrotik.com/t/sxt-back-to-default-configuration-after-each-reboot/64236/1
Check also
/system routerboard settings set enable-jumper-reset=no
If it still does not work, then boot the routerboard, complete the configuration you want and then export it:
/export file=sxt5hpnd
copy the file into your computer, and then do netinstall loading the file you saved into
“configure script” of the netinstall window. Every time the routerboard will reboot it will load this configuration as its default.
