Mikrotik SXT Lite-2 indoor use
Good day. I have two office on 6th and 7th stages in one building and need to bridge networks between them. There is no way to cable connection. I want to bridge them using WiFi and SXT Lite-2 on one side and RB951 on another.
Is it a good idea to use SXT indoors? What about directional antenna? Will it work indoors? Thanks
interesting topic
hi.
please remember wireless is “two-way communication”
RB951 made for home use it low tx-power
you can use SXT-Lite2 for indoor but i’m not sure match between SXT + RB951 :smiley:
sorry for english if u not understand
[SXT]))))))))))))))))))))))))))))))))))*
---------------------------*(((((((([RB951]))))))))
SXT=directional antenna
RB951=omni antenna
SXT can talk to RB951
but
RB951 can’t talk to SXT because
1.low TX-Power
2.no directional antenna
I wouldn’t use 2.4GHz for a PTP, specially indoors where the 2.4Ghz spectrum should be rather crowded, but 5GHz.
I’d try with a couple SXT5 Lite in PTP (tame down power as needed), with a 951Ui-2HnD to provide 2.4Ghz wireless coverage, that way you can even power the SXT from port 5 on it; is also one of the best 2.4GHz APs in terms of radio.
https://www.google.ro/search?q=powerline+adapter&espv=2&biw=1920&bih=889&source=lnms&tbm=isch&sa=X&ei=e5VMVbmiHMSBU8mXgdAI&ved=0CAYQ_AUoAQ
Much better.
completely agree… that’s the first option provided it works.
Maybe I can use two SXT to establish connection between offices? Will some concrete walls be a problem?
You’ll have to check. but the best solution is always… cable :smiley:
agree
