how do i configure the sxt lte cpe so than i can have better signal at the farm,do i need to insert sim cards or it can just boost the signal to our fones please help
SXT LTE is not LTE signal booster. If you install it (including SIM card), it will become WiFi access point while using LTE as WAN connection. Your phones will use it as data connection (it won’t help for ordinary phone calls, but it will help forVoIP, such as skype, viber or other similar solutions).
thank you,what is the best solution i could opt for?
It depends what you’re aiming for … if you want to boost LTE signal so that your phones will work better, then you need LTE signal booster … but Mikrotik doesn’t produce those. If data services are what you need, then SXT LTE kit can be the right device for you.
