Mikrotik SXT
I have ordered myself a few SXT but I have noticed that they are really weak, I cannot even connect to a link that is more than 5km, I am running Dbii F50 Pro Radios on the 16dbu sectors, and these SXT on 2km Have an signal quality of -85, Is that normal?
You are loosing 20dB somewhere…
For your 2Km link, you should have signal at -65dB, and they are very accurate for calcs of signal prediction.
Clear LOS?
Clean Fresnel?
MMCX pigtails?
Sector antenna quality?
I have a bunch of them working and they are quite amazing for it´s price.
Link between two SXT with 4,1Km clear LOS and clean fresnel, signal is -73dB rock solid.
Kindly regards,
SXT’s are not weak, you have a problem somewhere and I believe is polarisation mismatch. By default SXT have only H pol. active. You must activate second chain.
Turn your SXT 90 degree and you will get adequate signal strength.
how SXT should be aligned ? 4 holes for air in below or at some side ? and then sign mikrotik is top to bottom ?
page 6: http://routerboard.com/pricelist/download_file.php?file_id=280
May be you need to use my Reflector SXT http://forum.mikrotik.com/t/reflector-sxt-live-test/48217/1 for a better result.
maybe but how we can buy it in Latvia ? looks like you are in ukraine ?
+1
Sounds like a polarity mismatch. The two SXTs I’ve been using get a lot better signal levels than what you’re seeing at those ranges.
you can use this reflector http://cn24.net/SXT-Shield-50.jpg then your SXT is safe . No rain will come into the holes.
Contact me by Email . We ship anywhere worldwide.
but in winter ? if snow covers inside of this box, and when after sun shines, there will be ice ! what about signal trough ice and snow?
now is Summer :slight_smile: we will see how does it performs in Winter.
Gerneraly ther is enough space arround the antenna for ice and snow.
I tihnk it will be better as the antenna without cover.
Because snow and ice will directly cover the antenna.
