Mikrotik SXTsq 5 ac (RBSXTsqG-5acD)
Mikrotik SXTsq 5 after setting it CPE mode and using as a bridge with static ip in Winbox it work ok, but after Winbox close can’t find it with Winbox.
It sets invisible for Winbox and to make some changes it need to be reset.
Is it possible to make it visible for Winbox after set CPE mode?
You dont see it, but can you access it by using its static IP Address ?
