Hello, I have a MikroTik SXTSQ Lite5 device running RouterOS_ARM version 6.49.19. I want to find a way to capture a network from a source to access the internet inside my house by connecting it to the router, but it doesn't respond when I select the source network. The message says "Searching for network." Please help me solve this problem. Is there an update for the device? Please let me know the latest version. Thank you.
The SXTSQ is a highly directional antenna, and 5 GHz only, so it depends on what the source is, usually these devices are used for point to point links, i.e. the source is another SXTSQ Lite5 or a similar device with vary narrow angle, and both devices need to be perfectly aligned.
Thanks for the answer, but if you mean the signal, then it's good. -52
A 5 GHz source at -52?
The source must be pretty close.
Anyway, post your configuration, instructions here:
There may be some settings that you forgot or misconfigured.
