Mikrotik taking ip
Hello friends !
I have a problem, my problem ; my ip is taking ip from router (exp: 10.5.50.X) but i wanted to take ip from modem (exp: 192.168.2.X)
i searched for 1-2days, i found port forwarding.but i dont understand cause for my bad english.
how to i bypass my ip thank you…
guys pls help i need so much.. :frowning:
Your modem is router too?
no its just modem.its running bridge mode. and i using mikrotik router
i mean my modem supports bridge(router) mode
You need to bridge the pc with the modem. Add the ports that connect those two interfaces to the same bridge.
yes i know that my friend.i must bridge my pc between modem. but i dont know the steps :frowning:(
See the manual.
Can u gıve me lınk? where i must to look ı dont know nothıng bro
http://wiki.mikrotik.com/wiki/Manual:Interface/Bridge
admin@MikroTik] /interface bridge> add
[admin@MikroTik] /interface bridge> print
0 R name=“bridge1” mtu=1500 l2mtu=65535 arp=enabled
mac-address=00:00:00:00:00:00 protocol-mode=none priority=0x8000
auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s
forward-delay=15s transmit-hold-count=6 ageing-time=5m
if i write this codes on the terminal is it work ? am i write my mac adress to ‘mac-address=00:00…’ ?
