This is a Cacti template for measuring Mikrotik RouterBoards temperature
Graph template:
Mikrotik - temperature (system temperature, cpu temperature, fan activity)
OID used:
sys_temp .1.3.6.1.4.1.14988.1.1.3.10.0
cpu_temp .1.3.6.1.4.1.14988.1.1.3.11.0
fan .1.3.6.1.4.1.14988.1.1.3.9.0
Installation:
copy mikrotik_temperature.php to <path_cacti>/scripts/ (mostly /var/www/cacti/scripts/)
import cacti template cacti_graph_template_mikrotik_-_temperature.xml from Console=>Import Templates
add graph for your device (Console=>Devices=>Create Graphs for this Host - Mikrotik temperature)
Attention!!
Low-cost RouterBoards has no fan nor temperature sensor. For more information check product specification or your hardware (system/health menu). Some examples:
RB411AH n/a
RB433AH n/a
RB711-5Hn n/a
RB800 cpu, fan
RB912UAG-5HPnD sys
OmniTIK UPA-5HnD sys
RB1000 fan
CCR1009-8G-1S cpu, sys, fan
CCR1036-12G-4S cpu, sys, fan
RB1100AHx2 cpu, sys, fan
RB2011iL n/a
MRTG is the core of almost every graphing application.
you can install it on windows or Preferably Linux (if you want to unleash this beast true powers)
I dunt have rb1100 version , but for CCR following is working.
