Hi All,
I accidently press something on my keyboard when remote via winbox to mikrotik router, after that, console display as below :
[user@] >
what does it mean ? how to restore the console/terminal to normal ?
Thanks.
George
Hi All,
[user@] >
Thanks.
George
Set the router identity
Go to “System > Identity” on winbox and change the name or you can use this command on a terminal:
/system identity set="YOUR DEVICE NAME"
Regards
Thats it ! I never thought it would be the router identity. Thanks Guys.
Regards,
George
