I have a Mikrotik RB951 series Wireless router and I am trying to setup an IPSEC VPN with a Fortigate Firewall. Whilst trying the configuration the Mikrotik continously crashes and I cannot test alot because of these interruptions. I managed to use WLAN 1 as the WAN interface and when I setup IPSEC all is ok until I configure the IPSEC Policy.
I am new to mikrotiks and first and foremost I would like to have a stable router on which to test. I have version 6.40.4. I was thinking of uninstalling some unwanted packages from it like mpls etc so that maybe could help. Anyone can help out about the stability issue or configuration ??
config system settings
set allow-subnet-overlap enable
config vpn ipsec phase1-interface
edit "TEST"
set interface "wan"
set peertype any
set proposal aes128-sha1
set dhgrp 5
set nattraversal disable
set remote-gw 2.2.2.2
set psksecret presharedkey
next
end
config vpn ipsec phase2-interface
edit "TEST"
set phase1name "TEST"
set dhgrp 5
set auto-negotiate enable
set encapsulation transport-mode
set protocol 47
set keylifeseconds 1800
next
end
config system gre-tunnel
edit "tunnel10"
set interface "TEST"
set local-gw 1.1.1.1
next
end
config system interface
edit "TEST"
set vdom "root"
set ip 1.1.1.1 255.255.255.255
set type tunnel
set remote-ip 2.2.2.2
set interface "wan"
next
end
edit "tunnel10"
set vdom "root"
set ip 172.16.2.37 255.255.255.255
set allowaccess ping
set type tunnel
set tcp-mss 1388
set remote-ip 172.16.2.38
set mtu-override enable
set mtu 1428
next
end
