Mikrotik to Juniper 5200
All, Having a difficult time getting RB750 to pass traffic thru to Juniper 5200 with IPsec tunnel aggressive mode. Can someone take a look and see what I did wrong? I believe I am having a Nat/Routing issue now but cannot figure out. I don’t completely understand the masquerading and IP chains.
The IPsec SA’s are flowing in both directions but cannot ping any devices from Lan of 750 to Lan of Juniper.
Scenario is as follows:
(PC-DHCP-172.16.132.126)<->(172.19.132.1/25-LAN)RB750(WAN-DHCP-Client)->Internet<-(WAN-Static)Juniper(LAN-Static-216.231.198.233)<->(216.231.198.234-PC-Static)
Here is my config:
[admin@MikroTik] > ip export
# jan/02/1970 03:09:23 by RouterOS 5.14
# software id = 9HDQ-0000
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=\
    0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default shared-users=1 status-autorefresh=1m \
    transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m name=default pfs-group=modp1024
add auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m name=juniper pfs-group=none
add name=pool-172.19.132.0/24 ranges=172.19.132.11-172.19.132.126
add address-pool=pool-172.19.132.0/24 authoritative=after-2sec-delay bootp-support=static disabled=no interface=\
    ether2-master-local lease-time=3d name=default
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=172.19.132.1/25 comment="default configuration" disabled=no interface=ether2-master-local network=172.19.132.0
/ip dhcp-client
add add-default-route=yes comment="default configuration" default-route-distance=1 disabled=no interface=ether1-gateway \
    use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=172.19.132.0/25 dhcp-option="" dns-server=8.8.8.8 gateway=172.19.132.1 ntp-server="" wins-server=""
add address=192.168.88.0/24 comment="default configuration" dhcp-option="" dns-server=192.168.88.1 gateway=192.168.88.1 \
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=4096 servers=""
/ip dns static
add address=192.168.88.1 disabled=no name=router ttl=1d
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s \
    tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
    tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="default configuration" disabled=no protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=established disabled=no
add action=accept chain=input comment="default configuration" connection-state=related disabled=no
add action=drop chain=input comment="default configuration" disabled=no in-interface=ether1-gateway
add action=masquerade chain=srcnat disabled=no dst-address=216.231.198.232/29 protocol=255 src-address=!172.19.132.0/25
add action=masquerade chain=srcnat comment="default configuration" disabled=no out-interface=ether1-gateway
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip ipsec peer
add address=216.231.198.13/32 auth-method=pre-shared-key dh-group=modp1024 disabled=no dpd-interval=1m \
    dpd-maximum-failures=2 enc-algorithm=3des exchange-mode=aggressive generate-policy=no hash-algorithm=sha1 lifebytes=0 \
    lifetime=10h my-id-user-fqdn=OM-ess-LAB2@xxxxxxx.com nat-traversal=no port=500 proposal-check=obey secret=\
    8888888888888888 send-initial-contact=yes
/ip ipsec policy
add action=encrypt disabled=no dst-address=216.231.198.232/29 dst-port=any ipsec-protocols=esp level=require priority=0 \
    proposal=juniper protocol=all sa-dst-address=216.231.198.13 sa-src-address=0.0.0.0 src-address=172.19.132.0/24 \
    src-port=any tunnel=yes
/ip neighbor discovery
set ether1-gateway disabled=yes
set ether2-master-local disabled=no
set ether3-slave-local disabled=no
set ether4-slave-local disabled=no
set ether5-slave-local disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no enabled=no max-cache-size=none \
    max-client-connections=600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 parent-proxy-port=0 port=\
    8080 serialize-connections=no src-address=0.0.0.0
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
[admin@MikroTik] >
