i used v 4.5 tried ping from mikrotik gateway to client local pc, result ping time 9 ms. please anybody explain
try it to a different PC.
I can get those ping speeds over 12 wireless hops.
screenshot or didn’t happen ![]()
OK 9 HOPS
But that is not the point.
The point is that the PC must be slow in response.
Or there is ALOT he has not shared.
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 4.5 (c) 1999-2010 http://www.mikrotik.com/
[…] > ping 10.10.10.3
10.10.10.3 64 byte ping: ttl=128 time=2 ms
10.10.10.3 64 byte ping: ttl=128 time=9 ms
10.10.10.3 64 byte ping: ttl=128 time=1 ms
12 packets transmitted, 12 packets received, 0% packet loss
round-trip min/avg/max = 1/7.7/9 ms
You haven’t even posted whether this is a wireless or a wired connection, what hardware the router is etc.
I used mikrotik on pc-router, connect by hub to lan wired 7 pc, before i’m using mikrotik v 3.28 ping time is 1 ms.. its normal?
maybe is ur simple queue. disable whole and test it again
replace the hub with a switch
MediaNet,
Just an FYI, View image.
are ALL those hops, wireless hops?
6 of those hops are wireless
Okay, then the results are believable.
Still good latency over 6 hops though ![]()
My maximum hops are 5 on my network and i get around 6-7ms latency
Now im using rb450g ros v4.6–hub–wired lan pc
10.10.10.5 64 byte ping: ttl=128 time=1 ms
10.10.10.5 64 byte ping: ttl=128 time=3 ms
10.10.10.5 64 byte ping: ttl=128 time=4 ms
10.10.10.5 64 byte ping: ttl=128 time=2 ms
10.10.10.5 64 byte ping: ttl=128 time=6 ms
10.10.10.5 64 byte ping: ttl=128 time=7 ms
I would still suggest that you follow RK’s advise and use a switch, rather than a hub.
