I have 2 mikrotik routers connected over L2TP Vpn connection, after connecting Router1 can not ping Router2 and Router2 can not ping Router1, i dont have access too from pc to Mikrotik server after my local Mikrotik is connected to first Mikrtoik Server.
I have setted all 4 networks in Route but nothing.
Anyone can help me what i need to do ?
Most likely you need to add routes or configure an automatic routing protocol.
But it is hard to say for sure because there is no information what you already configured.
Mikrotik Server:
add address=192.168.1.2/24 interface=WAN network=192.168.1.0
add address=10.1.10.1/24 interface=Bridge1 network=10.1.10.0
add disabled=no distance=1 dst-address=10.1.100.0/24 gateway="L2TP-Xelmep Server" \
routing-mark=VPNfromDE-10.100
add disabled=no distance=1 dst-address=10.1.10.0/24 gateway="L2TP-Xelmep Server" \
add disabled=no distance=1 dst-address=192.168.1.0/24 gateway="L2TP-Xelmep Server" \
routing-mark=VPNfromDE-192.168
add disabled=no distance=1 dst-address=192.168.178.0/24 gateway="L2TP-Xelmep Server" \
routing-mark=VPNfromDE-192.178
add distance=1 gateway=192.168.1.1
/interface l2tp-server
add name="L2TP-Xelmep Server" user=""
/interface l2tp-server server
set allow-fast-path=yes default-profile=L2TP/IPSec enabled=yes use-ipsec=yes
/ppp profile
add local-address=10.1.10.1 name=VPN-Profil remote-address=dhcp_pool1 use-encryption=\
no use-mpls=yes
add bridge=Bridge1 dns-server=8.8.8.8 local-address=10.1.10.1 name=L2TP/IPSec \
remote-address=dhcp_pool1 use-encryption=yes use-mpls=yes
add action=accept chain=forward src-address-list=A-InLan
add action=accept chain=forward dst-address-list=A-InLan
add action=accept chain=input comment="Accept related" connection-state=related
add action=accept chain=forward comment="Accept gre" connection-limit=100,32 \
in-interface=WAN protocol=gre
add action=accept chain=forward comment="WANtoLAN L2TP" out-interface=WAN src-address=\
192.168.178.2
add action=accept chain=forward comment="Open L2TP ports 500,1701,4500" dst-port=\
500,1701,4500 in-interface=WAN protocol=udp
add action=accept chain=input comment="Allow-LAN and VPN" src-address-list=A-InLan
add action=log chain=input comment="Drop BlackList Brute Force" dst-port=\
21,22,23,80,85,500,1701,1723,4500,8291 log-prefix=BlackList_DropLog protocol=tcp \
src-address-list=BlackList_log
add action=drop chain=input comment="Drop BlackList Brute Force" src-address-list=\
BlackList
add action=drop chain=input comment="Drop Ping" disabled=yes in-interface=WAN \
protocol=icmp
add action=drop chain=forward connection-limit=15,32 disabled=yes dst-address-list=\
BlackList protocol=tcp
add action=accept chain=forward comment="VPN Gra" in-interface=WAN protocol=gre
add action=accept chain=forward comment="Allow Main Router - FritzBox" src-address=\
192.168.1.1
add action=drop chain=input comment="Drop ssh brute forcers" dst-port=22 protocol=tcp \
add action=add-src-to-address-list address-list=BlackList address-list-timeout=\
none-static chain=input connection-state=new dst-port=22 protocol=tcp \
src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 address-list-timeout=5m \
chain=input connection-state=new dst-port=22 protocol=tcp src-address-list=\
ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=5m \
ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 address-list-timeout=5m \
add action=drop chain=input comment="Drop telnet brute forcers" dst-port=23 protocol=\
tcp src-address-list=BlackList
none-static chain=input connection-state=new dst-port=23 protocol=tcp \
src-address-list=telnet_stage3
add action=add-src-to-address-list address-list=telnet_stage3 address-list-timeout=5m \
chain=input connection-state=new dst-port=23 protocol=tcp src-address-list=\
telnet_stage2
add action=add-src-to-address-list address-list=telnet_stage2 address-list-timeout=5m \
telnet_stage1
add action=add-src-to-address-list address-list=telnet_stage1 address-list-timeout=5m \
add action=drop chain=input comment="Drop Web80 brute forcers" dst-port=80 protocol=\
none-static chain=input connection-state=new dst-port=80 protocol=tcp \
src-address-list=Web80_stage3
add action=add-src-to-address-list address-list=Web80_stage3 address-list-timeout=\
none-dynamic chain=input connection-state=new dst-port=80 protocol=tcp \
src-address-list=Web80_stage2
add action=add-src-to-address-list address-list=Web80_stage2 address-list-timeout=5m \
chain=input connection-state=new dst-port=80 protocol=tcp src-address-list=\
Web80_stage1
add action=add-src-to-address-list address-list=Web80_stage1 address-list-timeout=5m \
add action=drop chain=input comment="Drop vpn1701 brute forcers" dst-port=1701 \
protocol=tcp src-address-list=BlackList
none-static chain=input connection-state=new dst-port=1701 protocol=tcp \
src-address-list=vpn1701_stage3
add action=add-src-to-address-list address-list=vpn1701_stage3 address-list-timeout=\
none-dynamic chain=input connection-state=new dst-port=1701 protocol=tcp \
src-address-list=vpn1701_stage2
add action=add-src-to-address-list address-list=vpn1701_stage2 address-list-timeout=5m \
chain=input connection-state=new dst-port=1701 protocol=tcp src-address-list=\
vpn1701_stage1
add action=add-src-to-address-list address-list=vpn1701_stage1 address-list-timeout=5m \
add action=drop chain=input comment="Drop vpn4500 brute forcers" dst-port=4500 \
none-static chain=input connection-state=new dst-port=4500 protocol=tcp \
src-address-list=vpn4500_stage3
add action=add-src-to-address-list address-list=vpn4500_stage3 address-list-timeout=5m \
chain=input connection-state=new dst-port=4500 protocol=tcp src-address-list=\
vpn4500_stage2
add action=add-src-to-address-list address-list=vpn4500_stage2 address-list-timeout=5m \
vpn4500_stage1
add action=add-src-to-address-list address-list=vpn4500_stage1 address-list-timeout=5m \
add action=drop chain=input comment="Drop Web85 brute forcers" dst-port=85 protocol=\
none-dynamic chain=input connection-state=new dst-port=85 protocol=tcp \
src-address-list=Web85_stage3
add action=add-src-to-address-list address-list=Web85_stage3 address-list-timeout=5m \
chain=input connection-state=new dst-port=85 protocol=tcp src-address-list=\
Web85_stage2
add action=add-src-to-address-list address-list=Web85_stage2 address-list-timeout=5m \
Web85_stage1
add action=add-src-to-address-list address-list=Web85_stage1 address-list-timeout=5m \
add action=accept chain=output comment=\
"Drop FTP Brute Force - Allow 'Incorrect Login' reply" content=\
"530 Login incorrect" dst-limit=1/1m,9,dst-address/1m protocol=tcp
add action=accept chain=forward in-interface=WAN protocol=gre
add action=accept chain=forward out-interface=WAN src-address=192.168.1.2
add action=accept chain=forward dst-port=500,1701,4500 in-interface=WAN protocol=udp
add action=accept chain=input connection-state=related
Mikrotik Client:
/interface l2tp-client
add allow-fast-path=yes connect-to=xxxxxxxxxx.ddns.net name=L2TPtoMK profile=L2TP-Profile \
use-ipsec=yes user=MikrotikHB
add distance=1 gateway=192.168.178.1
add distance=1 dst-address=10.1.10.0/24 gateway=L2TPtoMK
add distance=1 dst-address=10.1.100.0/24 gateway=L2TPtoMK
add distance=1 dst-address=192.168.1.0/24 gateway=L2TPtoMK
add distance=1 dst-address=192.168.178.0/24 gateway=L2TPtoMK
add action=accept chain=forward comment="Accept gre" connection-limit=100,32 in-interface=WAN \
protocol=gre
add action=accept chain=forward comment="WANtoLAN" out-interface=WAN src-address=\
192.168.178.2
add action=accept chain=forward comment="Open L2TP ports 500,1701,4500" dst-port=500,1701,4500 \
add action=drop chain=input comment="Drop BlackList Brute Force" src-address-list=BlackList
add action=drop chain=input comment="Drop Ping" disabled=yes in-interface=WAN protocol=icmp
add action=drop chain=forward connection-limit=15,32 disabled=yes dst-address-list=BlackList \
protocol=tcp
add action=accept chain=forward comment="VPN Gra" disabled=yes in-interface=WAN protocol=gre
add action=accept chain=forward comment="Allow Main Router - FritzBox" disabled=yes \
dst-address-list=A-InLan in-interface=bridge1 out-interface=bridge1 src-address-list=\
A-InLan
add action=add-src-to-address-list address-list=BlackList address-list-timeout=none-static \
chain=input connection-state=new dst-port=22 protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 address-list-timeout=5m chain=input \
connection-state=new dst-port=22 protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=5m chain=input \
connection-state=new dst-port=22 protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 address-list-timeout=5m chain=input \
add action=drop chain=input comment="Drop telnet brute forcers" dst-port=23 protocol=tcp \
chain=input connection-state=new dst-port=23 protocol=tcp src-address-list=telnet_stage3
add action=add-src-to-address-list address-list=telnet_stage3 address-list-timeout=5m chain=\
input connection-state=new dst-port=23 protocol=tcp src-address-list=telnet_stage2
add action=add-src-to-address-list address-list=telnet_stage2 address-list-timeout=5m chain=\
input connection-state=new dst-port=23 protocol=tcp src-address-list=telnet_stage1
add action=add-src-to-address-list address-list=telnet_stage1 address-list-timeout=5m chain=\
add action=drop chain=input comment="Drop Web80 brute forcers" dst-port=80 protocol=tcp \
chain=input connection-state=new dst-port=80 protocol=tcp src-address-list=Web80_stage3
add action=add-src-to-address-list address-list=Web80_stage3 address-list-timeout=none-dynamic \
chain=input connection-state=new dst-port=80 protocol=tcp src-address-list=Web80_stage2
add action=add-src-to-address-list address-list=Web80_stage2 address-list-timeout=5m chain=\
input connection-state=new dst-port=80 protocol=tcp src-address-list=Web80_stage1
add action=add-src-to-address-list address-list=Web80_stage1 address-list-timeout=5m chain=\
add action=drop chain=input comment="Drop vpn1701 brute forcers" dst-port=1701 protocol=tcp \
chain=input connection-state=new dst-port=1701 protocol=tcp src-address-list=vpn1701_stage3
none-dynamic chain=input connection-state=new dst-port=1701 protocol=tcp src-address-list=\
vpn1701_stage2
add action=add-src-to-address-list address-list=vpn1701_stage2 address-list-timeout=5m chain=\
input connection-state=new dst-port=1701 protocol=tcp src-address-list=vpn1701_stage1
add action=add-src-to-address-list address-list=vpn1701_stage1 address-list-timeout=5m chain=\
add action=drop chain=input comment="Drop vpn4500 brute forcers" dst-port=4500 protocol=tcp \
chain=input connection-state=new dst-port=4500 protocol=tcp src-address-list=vpn4500_stage3
add action=add-src-to-address-list address-list=vpn4500_stage3 address-list-timeout=5m chain=\
input connection-state=new dst-port=4500 protocol=tcp src-address-list=vpn4500_stage2
add action=add-src-to-address-list address-list=vpn4500_stage2 address-list-timeout=5m chain=\
input connection-state=new dst-port=4500 protocol=tcp src-address-list=vpn4500_stage1
add action=add-src-to-address-list address-list=vpn4500_stage1 address-list-timeout=5m chain=\
add action=drop chain=input comment="Drop Web85 brute forcers" dst-port=85 protocol=tcp \
add action=add-src-to-address-list address-list=BlackList address-list-timeout=none-dynamic \
chain=input connection-state=new dst-port=85 protocol=tcp src-address-list=Web85_stage3
add action=add-src-to-address-list address-list=Web85_stage3 address-list-timeout=5m chain=\
input connection-state=new dst-port=85 protocol=tcp src-address-list=Web85_stage2
add action=add-src-to-address-list address-list=Web85_stage2 address-list-timeout=5m chain=\
input connection-state=new dst-port=85 protocol=tcp src-address-list=Web85_stage1
add action=add-src-to-address-list address-list=Web85_stage1 address-list-timeout=5m chain=\
