Greetings,
Have been playing with a hAP ac RB962UiGS-5HacT2HnT for about a month. It has been a very steep learning curve.
Have 20+ Gargoyle routers and they are getting old and unreliable and they are needing to be replaced more frequently, so looking to migrate to Mikrotik.
The main issue I have at this point in time is configuring the DHCP address range. I cannot find a resource that explains the concepts/steps I need to configure this.
Due to existing setups I need to setup the DHCP server to issue addresses in the 192.168.100.1/24 range. I keep locking myself out of the router and after 100+ hours of failing, could you please assist me? A resource that explains the concepts, so I can learn would be great, but at this stage a simple answer would suffice.
Thank you in advance.
Here is an export of a base configuration that I am working with:
# aug/31/2016 13:04:05 by RouterOS 6.36
# software id = Q4Q4-R643
add admin-mac=E4:8D:8C:6B:C3:6B auto-mac=no comment=defconf name=bridge
add name=bridge-iptc
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/ip neighbor discovery
set ether1 discover=no
set bridge comment=defconf
/interface vlan
add interface=ether1 name=vlan500 vlan-id=500
add interface=ether1 name=vlan600 vlan-id=600
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan500 max-mru=1492 max-mtu=\
1492 name=unifi password=PASSWORD use-peer-dns=yes user=USER
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=\
allowed mode=dynamic-keys name="Cam Key" supplicant-identity="" \
wpa-pre-shared-key=0416431737 wpa2-pre-shared-key=0416431737
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
disabled=no distance=indoors frequency=auto mode=ap-bridge security-profile=\
"Cam Key" ssid=2GHz wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee \
"Cam Key" ssid=5GHz wireless-protocol=802.11
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge-iptc interface=ether4
add bridge=bridge-iptc interface=vlan600
192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes servers=\
8.8.8.8,8.8.4.4,208.67.222.222,208.67.220.220
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment="defconf: accept established,related" \
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=\
ether1
add action=accept chain=forward comment="defconf: accept established,related" \
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment="defconf: masquerade" log-prefix="" \
out-interface=unifi
/system clock
set time-zone-name=Asia/Kuala_Lumpur
/system routerboard settings
set cpu-frequency=720MHz protected-routerboot=disabled
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
