Mikrotik /tool fetch help needed in a Script
Hi everyone,
I would like to use /tool fetch url=(“https://site.com”) keep-result=no to monitor my website but over a specific interface, which is an LTE interface.
I now that I can use Netwatch basically, which I do, or ping scripts, but this is a specific case where I explicitly need an LTE interface to monitor a web throuh fetch command.
Can that be achieved?
Ideas?
Thanks,
pyra
you can create a route to an IP address site over interface LTE
after an “/tool fetch”, delete or disable
