Mikrotik UPS Support since 6.4x.x
HI,
I have several x86 and Mikrotik systems running on ROS 6.39.3 with a APC Smart-UPS C 1000 FW:UPS 10.0 / ID=1005
The UPS is connected by USB
They show the following info:
  • Model
  • Serial Number
  • Manufacture date
  • Nominal Battery Voltage
  • Run time left
    -Battery Change
  • Line Voltage
  • Status: On Line
However, i have some newer systems running ROS 6.40.7 and 6.41.2 and i am missing a lot of UPS info on these systems.
The connected UPS’s are exactly the same as stated above, with same firmware and ID.
But all the info i get is:
  • Serial Number
  • Run time left
  • Status: On Line
Is this a bug or is Mikrotik dropping support for APC Smart UPS’s?
Best Regards,
Ammer
Hello
In the changelog as per link below, I see that in version 6.42 there have been some modifications regarding the UPS.
If possible, upgrade to test.
Information about what was updated in the versions
https://mikrotik.com/download/changelogs/
Hi Leoservices,
I updated to 6.42.1 and still no change in the UPS information shown.
I’ll send a support request to Mikrotik.
Did you get back any support/information on how to get this solved or will downgrading be the only option to get a Smart UPS working with a MikroTik device?
