Mikrotik User Manager
how about a total-megabytes field for the users - i want to limited users to say - 10gb a month total upload/download
Also what happens when the user runs out of download/upload - would be nice to be abel to excute a script when they run out of time - so we could alter their queue and change the prority
Can i export my users from a mikrotik hotspot 2.8.28 and import in a 2.9.23 user manager?
Thanks!
Alessio
Normis, can import users from the local hotspot mikrotik database to the usermanager?
Thanks!
Alessio
export the ip hotspot user menu, edit the txt file to be compatible with the tool user-manager syntax and import there. i hope that you are aware that you can add users not only from web interface, but also from command line?
what about disk requirements? i’m using 32mb CF and have 10 megs free bytes, how many user can it handle before the disk out of space?
At last i managed to see the left side of the user manager page using FIREFOX !!!
after that i added 3 users as samples , thier IP’s already exeist in the DHCP leases table , but , no active users in the list ???
all the users who already were connected they dissconnected !!!
hardly , and deadly tries after tries the connect again after disabling the user-manager package , uninstalling it !!! could anybody tell me why ??? how can i really use this package ?? how could any client connect to my router when this package is active and the client details are exist in it ..
Thanks for the radius manager i had been testing it with my office building and it working well but i want to ask one question that is if it possible to fix bandwidth rate per user, and also like add calendar, so that when creating a user to set the date his subscription will expire thanks
yes, it is possible. test a little more, and you will see these features for each user that you add.
I have activated PAP authentication in the client machine for my pppoe server . I can login into the pppoe server only if I have a secret into the pppoe profile but user manager doesn’t show any usage for that account . And if I add any customer from the web interface of user manager then I can’t even login into the user manager with the newly created customer login name. But if I create any user from the command line then I can login from the web interface. I don’t know what am I missing . I have ticked to use radius into the pppoe profile and also ticked to accept request from the radius . I have used the router local ip 10.0.0.1 and also with the public ip and the secret correctly and have also tried with the 127.0.0.1 IP. Then what am I missing . .
admin@uol.com] > /tool user-manager user print
Flags: X - disabled, A - active
0 subscriber=admin username=“zubair” password=“1234” ip-address=10.1.0.10 pool-name=“pppoe” last-seen=never
credit-count=1 credit-left=4w2d credit-duration=4w2d credit-price=1800 credit-till-time=jan/01/1970 00:00:00
credit-time-added=4w2d
1 subscriber=admin username=“aliosha” password=“1234” last-seen=never credit-count=0 credit-left=0s credit-duration=0s
credit-price=0 credit-till-time=jan/01/1970 00:00:00 credit-time-added=0s
[admin@uol.com] >
I hope I have created user correctly …
My pppoe server and the usermanager is running on the same machine . Then what the hell am I missing???
Can anybody please help me out to get it done ???
I will be waiting to hear from somebody ….
Please post the user-manager configuration and the logs.
*Radius client configuration
*User manager configuration
*Logs from the user manager and from the router itself when you try to login using pppoe using pap.
here is MT oS settings
[admin@uol.com] > /ppp
aaa active export profile secret
[admin@uol.com] > /ppp aaa
edit export get print set
[admin@uol.com] > /ppp aaa print
use-radius: yes
accounting: yes
interim-update: 10s
[admin@uol.com] > /ppp profile print
Flags: * - default
0 * name=“default” use-compression=default use-vj-compression=default use-encryption=default only-one=default
change-tcp-mss=default
1 * name=“default-encryption” local-address=10.1.0.1 remote-address=10.1.0.12 use-compression=default
use-vj-compression=default use-encryption=yes only-one=default change-tcp-mss=default
dns-server=203.91.141.3,203.91.141.4
[admin@uol.com] >
[admin@uol.com] > /radius print
Flags: X - disabled
SERVICE CALLED-ID DOMAIN ADDRESS SECRET
0 ppp 10.1.0.1 203.91.145.187
userman user list
2 subscriber=admin username=“prince” password=“1234” ip-address=202.55.22.6 pool-name=“corporate” last-seen=never
MY ROUTER LOG PRINT
[admin@uol.com] > /log print
00:47:05 pppoe,ppp,debug,packet userman: <ms-dns 0.0.0.0>
00:47:05 pppoe,ppp,debug,packet userman: <ms-wins 0.0.0.0>
00:47:05 pppoe,ppp,debug,packet userman: <0012>: sent IPCP ConfRej id=0x5
00:47:05 pppoe,ppp,debug,packet userman: <comp VJ f 1>
00:47:05 pppoe,ppp,debug,packet userman: <0012>: rcvd IPCP ConfAck id=0x1
00:47:05 pppoe,ppp,debug,packet userman: <addr 10.1.0.1>
00:47:05 pppoe,ppp,debug,packet userman: <0012>: rcvd CCP ConfAck id=0x1
00:47:05 pppoe,ppp,debug,packet userman: <0012>: rcvd CCP TermReq id=0x6
00:47:05 pppoe,ppp,debug,packet userman: cRU\CD\00<\CDt\00\00\02\DC
00:47:05 pppoe,ppp,debug,packet userman: <0012>: sent CCP TermAck id=0x6
00:47:05 pppoe,ppp,debug,packet userman: <0012>: rcvd IPCP ConfReq id=0x7
00:47:05 pppoe,ppp,debug,packet userman: <addr 0.0.0.0>
00:47:05 pppoe,ppp,debug,packet userman: <0012>: sent IPCP ConfNak id=0x7
00:47:05 pppoe,ppp,debug,packet userman: <addr 10.1.0.13>
00:47:05 pppoe,ppp,debug,packet userman: <ms-dns 203.91.141.3>
00:47:05 pppoe,ppp,debug,packet userman: <ms-dns 203.91.141.4>
00:47:05 pppoe,ppp,debug,packet userman: <0012>: rcvd IPCP ConfReq id=0x8
00:47:05 pppoe,ppp,debug,packet userman: <0012>: sent IPCP ConfAck id=0x8
00:47:05 pppoe,ppp,debug userman: <0012>: IPCP opened
00:47:05 pppoe,ppp,info : connected
00:47:05 pppoe,ppp,info,account aliosha logged in, 10.1.0.13
00:47:05 route,event userman: Up
00:47:05 route,event userman: Interface
00:47:05 route,event userman: Link up
00:47:05 route,event userman: Add
00:47:05 route,event userman: Address=10.1.0.1/32
00:47:05 route,event userman: Added candidate route
00:47:05 route,event userman: DstAddress=10.1.0.13/32
00:47:05 route,event userman: Attributes
00:47:05 route,event userman: type=CONNECT
00:47:05 route,event userman: dst=10.1.0.13/32
00:47:05 route,event userman: scope=10
00:47:05 route,event userman: targetscope=0
00:47:05 route,event userman: connet
00:47:05 route,event userman: address=10.1.0.1
00:47:05 route,event userman: netmask=255.255.255.255
00:47:05 route,event userman: ifaceIdx=26
00:47:05 route,event userman: origin-id=1
00:47:05 route,calc userman: Tag destination for recalculation
00:47:05 route,calc userman: DstAddress=10.1.0.13/32
00:47:06 route,calc userman: Begin calculation
00:47:06 route,calc userman: Select active connected routes
00:47:06 route,calc userman: Select connected route
00:47:06 route,calc userman: DstAddress=10.1.0.13/32
00:47:06 route,calc userman: Attributes
00:47:06 route,calc userman: type=CONNECT
00:47:06 route,calc userman: dst=10.1.0.13/32
00:47:06 route,calc userman: scope=10
00:47:06 route,calc userman: targetscope=0
00:47:06 route,calc userman: connet
00:47:06 route,calc userman: address=10.1.0.1
00:47:06 route,calc userman: netmask=255.255.255.255
00:47:06 route,calc userman: ifaceIdx=26
00:47:06 route,calc userman: origin-id=1
00:47:06 route,calc userman: Exclude from further calculation
00:47:06 route,calc userman: Update route nexthops
00:47:06 route,calc userman: Redistribute updates
00:47:06 route,calc userman: Route change
00:47:06 route,calc userman: OldAttributes=(nothing)
00:47:06 route,calc userman: NewAttributes
00:47:06 route,calc userman: End calculation
00:47:25 pppoe,ppp,debug,packet userman: <0012>: rcvd LCP EchoReq id=0x14
00:47:25 pppoe,ppp,debug,packet userman: <magic 0xcd555263>
00:47:25 pppoe,ppp,debug,packet userman: 52 53 50 45
00:47:25 pppoe,ppp,debug,packet userman: <0012>: sent LCP EchoRep id=0x14
00:47:25 pppoe,ppp,debug,packet userman: <magic 0x699bdb82>
00:47:45 pppoe,ppp,debug,packet userman: <0012>: rcvd LCP EchoReq id=0x15
00:47:45 pppoe,ppp,debug,packet userman: <magic 0xcd555263>
00:47:45 pppoe,ppp,debug,packet userman: 52 53 50 45
00:47:45 pppoe,ppp,debug,packet userman: <0012>: sent LCP EchoRep id=0x15
00:47:45 pppoe,ppp,debug,packet userman: <magic 0x699bdb82>
00:47:48 system,info,account user admin logged in via local
By this setting I can not see any log in user manager
and when I remove ppp secret then …I [admin@uol.com] > /log print
00:55:06 route,calc userman: connet
00:55:06 route,calc userman: address=10.1.0.1
00:55:06 route,calc userman: netmask=255.255.255.255
00:55:06 route,calc userman: ifaceIdx=26
00:55:06 route,calc userman: origin-id=1
00:55:06 route,calc userman: NewAttributes=(nothing)
00:55:06 route,calc userman: End calculation
00:55:08 pppoe,debug,packet userman: corporate: rcvd PADI from 00:C0:26:00:48:96
00:55:08 pppoe,debug,packet userman: session-id=0x0000
00:55:08 pppoe,debug,packet userman: service-name=PPPOE
00:55:08 pppoe,debug,packet userman: host-uniq=52 53 50 45 00 00 00 00 7c f5 7e 39 24 80 c6 01
00:55:08 pppoe,debug,packet userman: corporate: sent PADO to 00:C0:26:00:48:96
00:55:08 pppoe,debug,packet userman: ac-name=uol.com
00:55:08 pppoe,debug,packet userman: corporate: rcvd PADR from 00:C0:26:00:48:96
00:55:08 pppoe,info PPPoE connection established from 00:C0:26:00:48:96
00:55:08 pppoe,ppp,debug userman: <0013>: PPP started
00:55:08 pppoe,ppp,info : waiting for call…
00:55:08 pppoe,ppp,debug userman: <0013>: PPP connected
00:55:08 pppoe,ppp,debug userman: <0013>: LCP lowerup
00:55:08 pppoe,ppp,debug userman: <0013>: LCP open
00:55:08 pppoe,debug,packet userman: corporate: sent PADS to 00:C0:26:00:48:96
00:55:08 pppoe,debug,packet userman: session-id=0x1300
00:55:08 pppoe,ppp,debug,packet userman: <0013>: rcvd LCP ConfReq id=0x0
00:55:08 pppoe,ppp,debug,packet userman: <mru 1492>
00:55:08 pppoe,ppp,debug,packet userman: <magic 0xcb345775>
00:55:08 pppoe,ppp,debug,packet userman: <mrru 1614>
00:55:08 pppoe,ppp,debug,packet userman: <ed 0x03 00 c0 26 00 48 96>
00:55:08 pppoe,ppp,debug,packet userman: <0x0d 03 06><0013>: sent LCP ConfReq id=0x1
00:55:08 pppoe,ppp,debug,packet userman: <mru 1488>
00:55:08 pppoe,ppp,debug,packet userman: <magic 0x4bd8027a>
00:55:08 pppoe,ppp,debug,packet userman: <0013>: sent LCP ConfRej id=0x0
00:55:08 pppoe,ppp,debug,packet userman: <0x0d 03 06><0013>: rcvd LCP ConfAck id=0x1
00:55:08 pppoe,ppp,debug,packet userman: <0013>: rcvd LCP ConfReq id=0x1
00:55:08 pppoe,ppp,debug,packet userman: <0013>: sent LCP ConfAck id=0x1
00:55:08 pppoe,ppp,debug userman: <0013>: LCP opened
00:55:08 pppoe,ppp,debug,packet userman: <0013>: rcvd LCP Ident id=0x2
00:55:08 pppoe,ppp,debug,packet userman: MSRASV5.10
00:55:08 pppoe,ppp,debug,packet userman: <0013>: rcvd LCP Ident id=0x3
00:55:08 pppoe,ppp,debug,packet userman: MSRAS-0-ZUBAIR
00:55:08 pppoe,ppp,debug,packet userman: <0013>: rcvd PAP AuthReq id=0x10
00:55:08 pppoe,ppp,debug,packet userman: <password 1234>
00:55:08 pppoe,ppp,debug userman: <0013>: PPP interface name is
00:55:08 pppoe,ppp,debug userman: <0013>: PPP authenticated
00:55:08 pppoe,ppp,debug,packet userman: <0013>: sent PAP AuthNak id=0x0
00:55:08 pppoe,ppp,debug,packet userman: Login incorrect
00:55:08 pppoe,ppp,error user aliosha authentication failed - radius timeout (6)
00:55:08 pppoe,ppp,error userman: user aliosha authentication failed - radius timeout (6)
00:55:08 pppoe,ppp,debug userman: <0013>: LCP close
00:55:08 pppoe,ppp,debug userman: <0013>: LCP closed
00:55:08 pppoe,ppp,debug userman: <0013>: CCP lowerdown
00:55:08 pppoe,ppp,debug userman: <0013>: CCP down event in initial state
00:55:08 pppoe,ppp,debug userman: <0013>: IPCP lowerdown
00:55:08 pppoe,ppp,debug userman: <0013>: IPCP down event in initial state
00:55:08 pppoe,ppp,debug,packet userman: <0013>: sent LCP TermReq id=0x2
00:55:08 pppoe,ppp,debug,packet userman: user aliosha authentication failed - radius timeout (6)
00:55:08 pppoe,ppp,debug,packet userman: <0013>: rcvd LCP TermAck id=0x2
00:55:08 pppoe,ppp,debug userman: <0013>: LCP lowerdown
00:55:08 pppoe,ppp,info : terminating… - user aliosha authentication failed - radius timeout (6)
00:55:08 pppoe,debug,packet userman: corporate: sent PADT to 00:C0:26:00:48:96
00:55:08 pppoe,ppp,debug userman: <0013>: PPP disconnected
00:55:08 pppoe,ppp,debug userman: <0013>: PPP destroy
00:55:08 pppoe,ppp,debug userman: <0013>: PPP stopped
00:55:08 pppoe,ppp,info : disconnected
00:55:08 pppoe,debug,packet userman: corporate: rcvd PADT from 00:C0:26:00:48:96
get
I hope these was all you wanted me to post
Thanks ..
they have fixed it and drop it on the site redownload it again and it will work
Hi, I guess we can chat sometime online so as to get t the bottom of usermanager… i need more help from you to configure my usermanager...cybergold3@yahoo.com… is my id..thanks
Still i’m facing the same problem . I downloded the the 9.24 packege as Ihave instructed and faced the same problem… :frowning:
Normiss,Uldiss,
Kindly come to the aid of your valued users… post a sweet reply on how to use the usermanager and lets all be happy…we cant know it all like u do… we want to be able to use usermanager as a perfect billing option.
what exactly is the problem? download package, install package, go to tools user-manager and add a user in tool user-manager customer add login=admin password=admin, then go to http://IPADDRESS//userman and log in with admin/admin
Great, yes we have all done that.. i have even printed some tickets of 1hr duration, but each time a customer gets to my hotspot login page and enters the password and esername generated on the ticket, he gets an error message.. invalid username… Thats our problem.. some of us are self taught MT users and for us to continue to enjoy MT, you have togive some little guidance and enough encouragement
look at the log files in the ‘tool user-manager log’ and also check the regular route logs. Have you enabled the Radius support for the hotspot?
Yes we can my yahoo ID is onowojemma@yahoo.com
I just installed 2.9.26 with User Manager for MIPS on an RB532 - have added a user but can’t access the web admin page at all.
No problems opening the web page on the X86 version so what is different here?
Trisc
