Goals and objectives you do not know!
I already use 6 years product mikrotik!
But the problem is and manufacturer’s support is nothing here in the forum can not explain!
and because u have a super computer u decide to make it all in one
just use 2 appliance with this CPU’s it can work as live backup an balancing
or try with THIS box of Iron
A certificate in the field of communication have in Russia at this piece of iron? I think not, and there is nothing to write
I’ve asked a question that I want to get an answer!
answer is simple closed source
some one forget to put in kernel some options
i386 kernel 2.4 limited to 16 logical cpu’s
kernel 2.6 is limited to 32
3.xx not sure
To get answer here in forum is like to wait for miracle…thats the reason why a lot of people hope of new edgemax routers of ubnt, and ubnt forum is one of the best on internet - best communication, developers listen to you and on every post you get good answer…
Here they just want to earn money for consultansts…
Make sure you have enabled RPS in the “system resources” menu.
We will try to increase number of supported cores. This has to be changed in the Kernel, so if there are no problems, maybe in the next RouterOS v6 version.
maratgub if you wish to test a pre-release, please email support.
