Mikrotik using wireguard as VPN client
Greetings fellow Mikrotik adventurers. I wanted to use Mikrotik as a mobile VPN router of sorts to connect to a wireguard VPN provider in Dallas so I can have a local presence regardless of location.
I found this helpful setup, https://www.ivpn.net/setup/router/mikrotik-wireguard using wireguard and Mikrotik. However, once implemented the VPN conectivity works perfectly fine, but I can no longer ping the router or use the web interface. Of course Winbox can still connect to it using the MAC address. I am using RouterOS 7.18.2. Could someone please help me determine what is missing in order to enable local traffic to the router itself? Thank you!
Here is the config:
# 2025-04-28 14:28:16 by RouterOS 7.18.2
# software id = xxxx-xxxx
# model = E50UG
# serial number = xxxxxxxxxx
add admin-mac=ff:ff:ff:ff:ff:FC auto-mac=no comment=defconf name=bridge
/interface wireguard
add listen-port=51820 mtu=1420 name=wireguard-proton-VPN
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.10-192.168.1.254
/routing table
add disabled=no fib name=wireguard-proton
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
/interface wireguard peers
add allowed-address=0.0.0.0/0 client-dns=10.2.0.1 endpoint-address=\
    xx.xx.xx.xx endpoint-port=51820 interface=wireguard-proton-VPN name=\
    Proton_VPN_USA persistent-keepalive=25s public-key=\
    "nZYSLxxxxxxx7yE1qRLQRFC71xHVEAg="
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
    192.168.1.0
add address=10.2.0.2 interface=wireguard-proton-VPN network=10.2.0.2
/ip dhcp-client
add address-pool=dhcp interface=bridge name=defconf
add address=192.168.1.0/24 comment=defconf dns-server=9.9.9.9 gateway=\
    192.168.1.1 netmask=24
set allow-remote-requests=yes servers=9.9.9.9
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat out-interface=wireguard-proton-VPN \
    src-address=192.168.1.0/24
add disabled=no dst-address=0.0.0.0/0 gateway=wireguard-proton-VPN \
    routing-table=wireguard-proton suppress-hw-offload=no
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/routing rule
add action=lookup-only-in-table disabled=no src-address=192.168.1.0/24 table=\
    wireguard-proton
/system clock
set time-zone-name=America/Chicago
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
Your “problem” is with this firewall rule:
Or better said … the fact you do not allow traffic coming from wireguard right before this drop rule.
There is nothing accepting input to your router coming from that wireguard interface.
Add specific rule accepting this traffic coming from wireguard interface or as an alternative, add wireguard interface to LAN list.
Thanks holvoetn, to be more specific, I cannot ping the Mikrotik from the LAN, I cant use the Mikrotik web interface from the LAN. When you say “the fact you do not allow traffic coming from wireguard right before this drop rule.”, isnt the ping traffic and web interface traffic already on the same subnet and not coming from the wireguard interface?
Ah, that’s another thing indeed.
Looks like you route all your traffic first to Proton VPN ?
Also local traffic.
Is this expected behavior? Is the Mikrotik supposed to be inaccessible when Wireguard is in use?
No, you have configured the mikrotik to ensure that the communication you seek is not available. In other words self-inflicted due to lack of knowledge.
The firewall rules are not the problem. The basis of error is a missing routing rule… Complete review follows.
You have not provided any of the information the 3rd party provided, and typically it should be
your wireguard ip address/32
endpoint address and port
private key for you to use when creating the MT wireguard interface (so that they already have your public key )
Public key to put in your MT peer settings.
Possibly DNS address.
Be aware that if you route all traffic out the wireguard tunnel, then of course you wont be able tor each the router …
So you need to articulate ALL user needs, and especially the admin. Which means the ability to configure the router while on the LAN.
You can circumvent this by taking one port off the bridge and making it accessible off bridge and thus not forced out the vpn internet.
This option will be provided at the very end.
In terms of the configuration…
  1. Not wrong or a problem, but src address is not needed is the source nat for wireguard ( not a firewall or routing function ), should be
  2. Again not that it matters but the MT listening port doesnt have to match the endpoint port. It can be anything.
  3. First real issue is the wireguard address on the MT
    add address=10.2.0.2**??** interface=wireguard-proton-VPN network=10.2.0.2
    should be:
    add address=10.2.0.2**/24** interface=wireguard-proton-VPN network=10.2.0.0
  4. If not using IPV6 then remove all associated noise (ipv6 firewall address lists)
    /ipv6 settings
    set disabled=yes
    add chain=input action=drop
    add chain=forward action=drop
  5. Remove default static DNS setting!!
    /ip dns static
  6. Remove remote requests:
    To:
    set servers=9.9.9.9
  7. Set DHCP server setting from:
    add address=192.168.1.0/24 comment=defconf dns-server=9.9.9.9 gateway=192.168.1.1 netmask=24
    TO:
    add address=192.168.1.0/24 dns-server=10.2.0.1 gateway=192.168.1.1
  8. Finally main issue, you need to add one rule to the routing rules … and order is important. So to get this as first rule without deleting the current rule simply copy the rule and accept, then after go back to the first rule and modify it from
    /routing rule
    add action=lookup-only-in-table disabled=no src-address=192.168.1.0/24 table=wireguard-proton
    TO:
    /routing rule
    add action=lookup-only-in-table dst-address=192.168.1.0/24 table=main
    add action=lookup-only-in-table src-address=192.168.1.0/24 table=wireguard-proton
Now you should be able to access the router as required.
Now to access the reqular internet through the local WAN, you will have to disable the wireguard interface and to go back to VPN internet, turn it back on, by enabling the wireguard interface.
OffBridge option…
What i recommend is create an offbridge port for local emergency access.
So remove etherX from /interface bridge port settings.
Modify the following entry
/ethernet
set [ find default-name=etherX ] name=OffBridgeX
Give it an Ip address
add address=192.168.77.1/30 interface=OffBridgeX network=192.168.77.0
Add it to the Interface List Members
add interface=OffBridgeX list=LAN
Now you should be able to plug your laptop into ether24, change the IPV4 settings on the laptop to 192.168.77.2, then using winbox enter the router with username and password.
Note the netmask of 30 on the address only allows two addresses to work on the router, .1 and .2.
Spectacular. It works perfectly.
Thank you so much for your guidance Anav. I will be posting a working “Mikrotik wireguard howto” in the appropriate forum section soon, since there isn’t currently an accurate working document anywhere on the internet. I will attribute your excellent contributions.
There used to be a quite good post (and other topics too) from a certain fire-spitting llama until he decided to remove all those posts for some obscure reason …
Just saying the bar has been raised pretty high as far as quality of such instruction post is concerned (on the other hand, there is nothing anymore now so …)
:laughing:
Obscure, not, simple transaction issue: No one paid my tariff of 365 belgian chocolates ( one for every day ). :wink:
