Mikrotik V3.10 Need urgent help to setup point-to-point link
good day..
I just received the Routerboard 433AH and the 4 pcs R52H after 4 day delivery waiting period.
But, i found that, the user manual come along in the mikrotik routerboard very big different and most of the commant cannot be use in the router board.
Can some expert can guide me how to setup the point to point link and the Nstrem2???
Thanks..
what manual did you use, and which command didn’t work?
just wonder know, why the R52h running on the 20Mhz channel bandwidth it only can up to 24Mbps with tested by ftp.
any mpci can help up to 30Mbps and above with only 20Mhz channel bandwidth?
which protocol ? 802.11g ?
if so, you have 54mbit/s over the air rate, which sums upto maximum of 24-28mbit/s real Ethernet level throughput.
Nope, it’s 802.11a, i have saw some artical talk about R52H work with mikrotik in 11a can up to 50Mbps and in turbo mode it can up to 70Mbps…
Just wonder know, how to make it?
Currently my setup is routerboard 1 running on bridge mode and routerboard 2 running on wds station.
Any good idea how can i increase the real user data rate throughput?
these numbers you can achieve by having perfect conditions with no interference, good line of sight and clean fresnel zone, good high gain antennas and perfect signal (-50 to -60)
found the problem..
in wds need to enable the nstreme…
one more question, what’s the different of the super channel?
superchannel you can use if you have a government permission to use different frequency than what is allowed in your regulations. if you need some special frequency, this mode will unlock it
frequency like???
what’s the cost of it???
and, it just for only 1 router board?
all frequencies that your wireless card supports (R52 supports ~~~ 2.3-2.6 and 4.9-6.0). each license per one routerboard. costs 10$
Can we TT for it if we needed it???
and what’s the procedure to upgrade for it???
contact your favorite distributor
i bought it from the www.routerboard.com, there are the distributor as well?
RouterBOARD.com = MikroTik.com = manufacturer
You can email sales@mikrotik.com about this question then
OK, noted.
Thanks.
