Dear all experts,
I have tried to send an email from Mikrotik to Gmail. I have tried many times to enable TLS and also tried to disable TLS but I couldn’t send email from Mikrotik to my Gmail for backup sets
it says Invalid From
Did that configuration work in an earlier version of ROS?
I just looked at my E-Mail settings in my RB4011 which is running 6.49.15 (so, a much earlier version). The only difference is that I am using TLS = Yes. Also, did you set up an application specific password in your G-Mail account settings for your router - and are you using that password?
Granted that it’s a much earlier version of ROS, but my RB4011 sends dozens of E-Mails every day via a G-Mail account.
Yes with the earlier version of ROS, it was working perfectly fine.
Yes, I’m using an application password from Gmail.
I think it is a problem with ROS’s new version
Bug in ROS
Any resolution on this? I seem to be having the same trouble
