Hi all.
I have a CRS125 with 6.42.3 on it.
Below is an image that shows a simplification of my setup with the important bits relevant to this post.
Extra info
LAN BRIDGE => Has DHCP server x.x.12.x/24 - Works as expected. Plug in cable, get address.
VLAN 20 => HAS DHCP SERVER - Works as Expected. Associate with WiFi, get VLAN 20 address. (VLAN 20 is an interface on LAN BRIDGE)
ISOLATE BRIDGE => NO DHCP SERVER. (Want the ETH ports on it to be tagged with VLAN 100)
VLAN 100 => HAS DHCP SERVER x.x.11.x/24 - Works as Expected. Associate with WiFi, get VLAN 100 address. (VLAN 100 is an interface on ISOLATE BRIDGE)
VLAN 200 => HAS DHCP SERVER - Works as x.x.10.x/24 Expected. Associate with WiFi, get VLAN 200 address.(VLAN 200 is an interface on ISOLATE BRIDGE)
On the UNIFI AP and UNIFI Switch I have all the relevant WiFi set up, there is one untagged wifi that works as expected, and then three tagged wifi’s that works as expected. On port 1 on the Unifi switch I have the untagged and VLAN20 network going to a port on the LAN BRIDGE, and that works fine.
On port 2 on the Unifi switch I have ONLY VLAN 100 and VLAN 200 configured, and when I associate with the WiFi SSID that has those VLAN tags I get routher through port 23 and out to the Internet.
(I am planning to isolate ISOLATE BRIDGE from the rest of the LAN, probably through some firewall rules denying access to between the various subnets, unless there is a way to just keep ISOLATE BRIDGE traffic away from LAN BRIDGE. But that is a later problem.)
My challenge is when I plug a PC into any of the ports on ISOLATE BRIDGE. Now I understand that if ISOLATE BRIDGE does not have a DHCP server, then I won’t get an address, that is expected behavior. My question is, how do I avoid having to add another DHCP server using the pool of VLAN 100? VLAN 200 will be WiFi only, but on VLAN 100 I will have wifi as well as Ether net devices. I could simply add another DHCP server to ISOLATE BRIDGE and use the VLAN 100 pool, but that is putting a bandaid on what I actually want. I want ports 17, 19 and 21 to be a part of VLAN 100 like any WiFi client that associates with the VLAN 100 SSID is.
I have used port 19 as my test subject, and have tried the following:
- Remove port 19 from ISOLATE BRIDGE > “Cannot remove dynamic port”
- Fine, REMOVE ISOLATE BRIDGE > OK, but I have INTERFACE LISTS! Ether 17, 19, 21, 23 are part of ISOLATE LIST (allowing for easy firewall rules yay) and now I cannot change port 19 because it is still seen as a dynamic port.
- Fine, REMOVE ISOLATE LIST > Nope, port 19 still dynamic.
(restore config, start again) - Change PVID of ISOLATE BRIDGE TO 100 > No effect, Interface still fails connection.
- CHANGE PVID of Port 19? > Cannot change dynamic port.
- What about changing the PVID of Isolate list? > “Couldn’t change bridge port interface list already added as bridge”
- MOVE DHCP SERVER TO ISOLATE BRIDGE > OK now Interface 19 gets DHCP, but VLAN 100 does not.
- Change port 19 under /interface/ethernet/switch and do various VLAN-y things based on various Mikrotik guides > No joy, the port still does not hand out DHCP.
(restore config, start again) - Add a VLAN to the Bridge with ID 100 and tag port 19 > no effect. (remove that bridge VLAN)
- Change PVID of ISOLATE BRIDGE to 100 and tick “VLAN FILTERING” > Now two dynamic VLANs appear under bridges, one with VLAN 100, and one with VLAN 1, on vlan 100 there are two entries for “ISOLATE BRIDGE” under “current untagged”, and two entries on VLAN 1 with port 23 and port 19 as “current untagged”. The DHCP client behavior of port 19 remains dead.
- OK, NOW move the DHCP server to ISOLATE BRIDGE? > Welp, now port 19 isn’t getting DHCP under this config either, but the wifi clients on VLAN 100 still does, so at least I have my VLAN getting DHCP when the bridge is PVID 100. That’s a step forward, but VLAN 100 now has no Internet access, so a step back there. A bonus is that I can also not see my onsite webserver which is on LAN BRIDGE, so isolation achieved, how to give them Internet Access though? I am happy to figure out that problem if I can get port 19 to behave as expected. Unfortunately VLAN 200 ALSO does not have Internet access when I set ISOLATE BRIDGE PVID to 100, but they do get addresses in the VLAN 200 pool still.
- Set the PVID of ISOLATE BRIDGE to 1, but enable VLAN tagging > OK, now I can also manually tag the VLAN on port 19 on ../bridge/vlans, and also get DHCP from the VLAN 100 SSID, as well as the VLAN 200 SSID, but NOT port 19, and none of the VLANs have access to Internet.
- under /interface/ethernet/switch/vlan do:
- ingress-vlan-translation add ports=ether19 customer-vid=0 new-customer-vid=100 sa-learning=yes
- vlan add ports=ether19 vlan-id=100 learn=yes
(Neither of the above allow me to plug a PC into port 19 and get any form of DHCP.)
At this point I reset my CRS to the last working config because keeping track of what I did gets hard and rolling back to where I get Internet + addresses on the VLAN 100 and 200 SSID’s is more effort than just hitting restore && reboot.
So that is what I tried, and I cannot get my VLAN setup to work like I want it. In short, without changing anything else that works as expected, I want:
ISOLATE BRIDGE - (VLAN 100 DHCP server)
- VLAN 100 - (Get VLAN 100 DHCP from ISOLATE BRIDGE)
- VLAN 200 - (VLAN 200 DHCP Server)
- ethernet17 (vlan 100) - (Client PC Get VLAN 100 DHCP from ISOLATE BRIDGE )
- ethernet19 (vlan 100) - (Client PC Get VLAN 100 DHCP from ISOLATE BRIDGE )
- ethernet21 (vlan 100) - (Client PC Get VLAN 100 DHCP from ISOLATE BRIDGE )
- ethernet23 (vlan 100 + vlan 200) - (WiFi SSID for VLAN 100 and VLAN 200 hand out DHCP on the espective VLANs as per the DHCP servers associated with those networks.)
I am unsure why interface lists are shown as bridges, but they are, and I cannot modify them, nor their client physical interfaces. I can also not remove client interfaces from a bridge once added, and once added to an interface list I cannot do anything with a physical interface, even if I delete the interface list. It’s like the physical interfaces are “locked down” and nothing short of a complete reset to default with no bridges and lists will allow me to meddle with them.
Making changes in /interface/ethernet/switch doesn’t seem to have any effect. Why there still isn’t a GUI for the switch port on 6.43 is unclear, it would be nice to have an interface to peer through and see if there are any problems.
Any advice will be appreciated.
