You cannot make ether23/ether24 simultaneously member ports of bridge1 and carrier interfaces for /interface vlan. If you need tagless frames on ether23 and ether24 to be bridged together and at the same time you need to bridge tagged frames between them, you must replace
/interface vlan
add interface=ether22 name=vlan22.110 vlan-id=110
add interface=ether23 name=vlan23.100 vlan-id=100
add interface=ether23 name=vlan23.110 vlan-id=110
add interface=ether24 name=vlan24.100 vlan-id=100
add interface=ether24 name=vlan24.110 vlan-id=110
by
/interface vlan
add interface=bridge1 name=vlan100 vlan-id=100
add interface=bridge1 name=vlan110 vlan-id=110
and forget about bridge100 and bridge110 completely - the IP configuration which you have attached to bridge100 and bridge110 has to be attached to vlan100 and vlan110 respectively instead.
If you want to make sure that frames tagged with some VID are only allowed to get in on the ports on which they are permitted, you have to configure vlan-filtering=yes and ingress-filtering=yes on bridge1 and also ingress-filtering=yes on the ports as you define their membership in the bridge.
So the complete configuration would be as follows:
add admin-mac=CC:2D:E0:28:2D:44 arp=proxy-arp auto-mac=no comment="created from master port" fast-forward=no name=bridge1 vlan-filtering=yes ingress-filtering=yes
/interface vlan
add bridge=bridge1 interface=ether1-master pvid=1 ingress-filtering=yes
add bridge=bridge1 disabled=yes interface=ether2 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether3 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether4 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether5 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether6 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether7 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether8 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether9 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether10 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether11 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether12 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether13 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether14 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether15 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether16 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether17 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether18 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether19 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether20 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether21 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether23 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=ether24 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=sfp-sfpplus1 pvid=1 ingress-filtering=yes
add bridge=bridge1 interface=sfp-sfpplus2 pvid=1 ingress-filtering=yes
/interface bridge vlan
add bridge=bridge1 vlan-ids=1 untagged=bridge1,ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,ether15,ether16,ether17,ether18,ether19,ether20,ether21,ether22,ether23,ether24,sfp-sfpplus1,sfp-sfpplus2
add bridge=bridge1 vlan-ids=100 tagged=bridge1,ether22,ether23,ether24
add bridge=bridge1 vlan-ids=110 tagged=bridge1,ether22,ether23,ether24
The configuration above supposes that on ether22, ether23, ether24 frames belonging to VLAN1 come/leave taggles and frames belonging to VLANs 100 and 110 come/leave tagged.
