I have a simple configuration that is not working (export below). I have created two VLANs (Private = 192.168.20.x & Public = 192.168.21.x) with two DHCP servers. As soon as I add the VLAN tagging
vlan-id=21 vlan-mode=use-tag
to the appropriate WLAN interface, I can no longer successfully connect wirelessly. Without this VLAN tag in the WLAN interface, I can connect to the SSID without any issues. Any ideas? Full export is below.
# jan/02/1970 00:22:59 by RouterOS 6.43.7
# software id = JVFK-X1M2
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 8A7D08DEEF06
add admin-mac=CC:2D:E0:E0:8D:3B auto-mac=no name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-WAN/Internet
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto mode=ap-bridge name=\
wlan-private-2ghz ssid=PrivateSSID wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto mode=\
ap-bridge name=wlan-private-5ghz ssid=PrivateSSID wireless-protocol=\
802.11
/interface vlan
add interface=bridge name=vlan-20-private vlan-id=20
add interface=bridge name=vlan-21-public vlan-id=21
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=profile \
/interface wireless
add disabled=no mac-address=CE:2D:E0:E0:8D:41 master-interface=\
wlan-private-2ghz name=wlan-public-2ghz security-profile=profile ssid=\
PublicSSID vlan-id=21 vlan-mode=use-tag
add disabled=no mac-address=CE:2D:E0:E0:8D:40 master-interface=\
wlan-private-5ghz name=wlan-public-5ghz security-profile=profile ssid=\
add name=dhcp-pool-20-private ranges=192.168.20.10-192.168.20.254
add name=dhcp-pool-21-public ranges=192.168.21.10-192.168.21.254
add address-pool=dhcp-pool-20-private disabled=no interface=vlan-20-private \
name=dhcp-server-20-private
add address-pool=dhcp-pool-21-public disabled=no interface=vlan-21-public \
name=dhcp-server-21-public
/interface bridge filter
add action=drop chain=forward in-interface=wlan-public-5ghz
add action=drop chain=forward out-interface=wlan-public-5ghz
add action=drop chain=forward in-interface=wlan-public-2ghz
add action=drop chain=forward out-interface=wlan-public-2ghz
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=sfp1
add bridge=bridge interface=wlan-private-2ghz
add bridge=bridge interface=wlan-private-5ghz
add bridge=bridge interface=wlan-public-5ghz
add bridge=bridge interface=wlan-public-2ghz
add comment=defconf interface=ether1-WAN/Internet list=WAN
add address=192.168.20.1/24 interface=vlan-20-private network=192.168.20.0
add address=192.168.21.1/24 interface=vlan-21-public network=192.168.21.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1-WAN/Internet
add address=192.168.20.0/24 gateway=192.168.20.1 netmask=24
add address=192.168.21.0/24 gateway=192.168.21.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.20.1 name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/tool mac-server
/tool mac-server mac-winbox
