Mikrotik VLAN with Access Point Configuration
I am trying to connect a Mikrotik Access Point to Mikrotik Router. I am able to get the AP (mostly) working, but it doesn’t get assigned an IP by the main router (and also can’t access the internet). I believe this is happening because the Mikrotik AP is not tagging it’s own traffic. I want the Mikrotik AP to be a part of VLAN 20 and pull it’s IP via DHCP from the main router. I’ve included the configuration from the Access Point below. I believe that the main router configuration is correct because when i use ether2-5 on the access point, I am able to successfully get an IP assigned by the router’s DHCP server and am a part of VLAN 20. What am i missing? Thank you for the help!
# jan/02/1970 00:01:19 by RouterOS 6.48
# software id = JVFK-X1M2
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 8A7D08DEEF06
add name=bridge vlan-filtering=yes
/interface wireless
# managed by CAPsMAN
set [ find default-name=wlan1 ] ssid=MikroTik
set [ find default-name=wlan2 ] ssid=MikroTik
/interface vlan
add interface=bridge name=vlan-20-private vlan-id=20
add interface=bridge name=vlan-21-public vlan-id=21
add interface=bridge name=vlan-22-kids vlan-id=22
add interface=bridge name=vlan-23-vpn-mn vlan-id=23
add name=WAN
add name=LAN
/ip hotspot profile
add bridge=bridge frame-types=admit-only-vlan-tagged ingress-filtering=yes \
    interface=ether1
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
    ingress-filtering=yes interface=ether2 pvid=20
    ingress-filtering=yes interface=ether3 pvid=20
    ingress-filtering=yes interface=ether4 pvid=20
    ingress-filtering=yes interface=ether5 pvid=20
add bridge=bridge interface=sfp1
add bridge=bridge interface=wlan2
add bridge=bridge interface=wlan1
/interface bridge vlan
add bridge=bridge tagged=bridge,ether1 untagged=ether2,ether3,ether4,ether5 \
    vlan-ids=20
add bridge=bridge tagged=ether1 vlan-ids=21
add bridge=bridge tagged=ether1 vlan-ids=22
add bridge=bridge tagged=ether1 vlan-ids=23
add interface=ether1 list=LAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=sfp1 list=LAN
add interface=wlan2 list=LAN
add interface=wlan1 list=LAN
/interface wireless cap
set discovery-interfaces=ether1 enabled=yes interfaces=wlan2,wlan1
add address=192.168.20.2/24 interface=vlan-20-private network=192.168.20.0
/system identity
set name=MO-STL-BEDROOM
Add bridge as a tagged member/interface of management vlan in bridge vlan table
Unlike @CZFan I don’t see an error in VLAN setup. However, according to configuration set, AP has static IP set (so it should be accessible within VLAN 20), but doesn’t have default route set (enough for it to not have internet access) nor does it have DNS server set (even if it did have IP connectivity to internet it could not access any named resource on the internet).
The rest of VLANs (21, 22, 23) are, as @CZFan noted, out of reach for AP’s CPU.
Which makes me wonder if wireless does get provisioned via CAPsMAN? /interface wireless cap is set to go via ether1 (which means untagged) … and ether1 is configured as trunk port (admit-only-vlan-tagged). IMO discovery interface should have been set to management VLAN interface (seems like vlan-20-private is the correct interface).
Apologies, @mkx correct, I quickly scanned over the config.
But I don’t see a dhcp client line item in config and that is probably reason AP can’t get IP from DHCP
Call me if you two can’t sort it out… me <---- busy, :wink:
I appreciate the responses from both of you! @mkx - Yes, you are correct - ether1 should be configured as a trunk port. Good catch on the CAPsMAN discovery interface. I have updated as recommended (and it does work; you were correct that it was not working). Is this the type of default route that you think I am missing? I am surprised that I need to set DNS because I was hoping that the access point would receive DNS from the router’s DHCP server for VLAN 20.
add distance=1 gateway=192.168.20.1
Here’s a current export with the CAPsMAN discovery interface fixed:
# jan/02/1970 00:08:36 by RouterOS 6.48
add name=bridge pvid=20 vlan-filtering=yes
/interface wireless
# channel: 2412/20-Ce/gn(28dBm), SSID: PRIVATE_CAP, local forwarding
set [ find default-name=wlan1 ] disabled=no ssid=MikroTik
# channel: 5180/20-Ceee/ac(27dBm), SSID: PRIVATE_CAP, local forwarding
set [ find default-name=wlan2 ] disabled=no ssid=MikroTik
/interface vlan
add name=WAN
add name=LAN
    interface=ether1 multicast-router=disabled
    vlan-ids=20
set discovery-interfaces=vlan-20-private enabled=yes interfaces=wlan2,wlan1
/ip dhcp-client
# DHCP client can not run on slave interface!
add disabled=no interface=ether1
# in/out-interface matcher not possible when interface (ether1) is slave - use master instead (bridge)
add action=masquerade chain=srcnat out-interface=ether1 src-address-list=\
    192.168.20.0/24
/system identity
A few things:
  1. remove pvid setting from bridge
  2. move DHCP client from ether1 to interface vlan-20-private
  3. add interface vlan-20-private to LAN interface list (not that it actually matters in your particular setup but it’s the right thing nonetheless)
  4. after DHCP client starts to work, remove static IP address … and remove the NAT rule
@mkx - Worked like a charm! Thank you so much!
