mikrotik vlans - trunk cisco
hi
i have a rb750r2 and i try to setup Vlan but i can not
i have at
ether1 wan1
ether5 pppoe
and i want at
ether4 4 vlans etc10,20,30,40 and this port (ether4) it is connect with trunk port of cisco with vlan 10, 20, 30 ,40 at port ether1. ether2 , etc (cisco setup is tested and work fine!!)
my ip range is 192.168.1.1-254
i have a pc that i have the ip 192.168.10.2
and i want from mikrotik to see the range 192.168.10.1-254 as vlan 10 forward the trafic of this pc only on ether4, tagged as vlan10
to have the from the cisco trunk port that trafic at ether 1 witch is vlan10
i have try it again and again but i did not make it play
is it easy to tell me the code i have to write at mikrotik?
sorry for my English..
