can mikrotik detect usb Vodafone HUAWEI E172 USB
this is a list of tested interfaces:
http://wiki.mikrotik.com/wiki/Supported_Hardware#3G_cards
If it’s not there, you are welcome to be the first one to test. If it will not work, we will try to add support based on your supout.rif file
solved with ROS 3.22
thanks you
