Hello community,
i have a RB1100AH with contrack enabled. If try outbound calls, i got the connection established but no voice. Inbound calls working fine.
There is no NAT on RB1100AH that could affect the VoIP since i have an offical ip but if i disable contrack, voice on outbound calls is transmitted fine immediatly.
The problem is, that there are some people without official IP, so contrac has to be enabled for NAT.
I also tried, if it is a problem with the nat rule, but disable the nat rule has no effect, neither add an accept rule to sort official IPs out of nat chain.
/ip firewall service-port sip enabled or disabled changed nothing.
RB 1100AH
ROS 5.20
/ip firewall address-list
add address=x.x.x.x/24 disabled=no list=nomasq
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=\
10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s \
udp-stream-timeout=3m udp-timeout=10s
/ip firewall mangle
add action=mark-routing chain=prerouting disabled=no new-routing-mark=kamax \
passthrough=yes src-address=192.168.67.1
add action=accept chain=srcnat disabled=no src-address-list=nomasq
add action=masquerade chain=srcnat disabled=no src-address-list=!nomasq
set ftp disabled=yes ports=21
set tftp disabled=yes ports=69
set irc disabled=yes ports=6667
set h323 disabled=yes
set sip disabled=yes ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
Any idea?
I hope my english is ok and i didn’t miss any information needed
Best regards
Manuel Ritter
