Mikrotik vs D-Link DWL-2100AP v2.10eu
Does not connect by WDS!!! Please do some thing!!! It`s very important!!
WDS is pretty much a hack and not a standard. There is no guaranteed compatability between vendors. Although, Mikrotik WDS tends to work with alot of vendors.
Eric
D-Link using Atheros AP-39 reference design for 2100, and Atheros firmware… same hardware&firmware use alot of vendors.. I think the problem is in the basic rates..
Just a thought, you are aware that dynamic-wds does not necessarily work with non routeros equipment. static-wds should work though.
it`s not work!!
so how do i get static to work. am having th same problem
they are connecting but they are not pinging
connecting but not pinging…could you be more specific-
if u mean not pinging something non wds side maybe you need to bridge the wds and LAN on the wds master.
i forgot to do this and could not hit my router.
saying these kinds of things will not give you answers. please clarify like described here: http://www.catb.org/~esr/faqs/smart-questions.html#before
If you find the answer how to connect D-Link 2100AP to mikrotik by wds i will pay $50!!!
The problem is in WDS protocol, not in bridging!
Just like I said, we need full description of the problem. You can’t get any solutuions just by saying it doesn't work. we don’t have this device and we can’t test it. so you must provide us your configuration, your device configuration, output of mikrotik logs etc.
are you serious abou tthis. i don tmind making that bucks off you cos i just got mine to work and it was just a really really small mistake i made. i got it to work perfectly
