Mikrotik wAP 60G AB, installation troubles
I just bought a Mikrotik wAP 60G AB routerboard. After wiring it to my router and searching for its wlan address in the Mikrotik app I get a login for the the RBaAPG-60d-A board offering an the IP 169.254.119.209. This, obviously, is not the default address and I can neither login nor use it for webfig. I can, however, log into the winbox using the MAC address, but do not know how to proceed from there. Could someone advise me on that problem? Thanks in advance,
h.h.
This is called Automatic Private IP Addressing or APIPA…
And what that simply means? When a device fails to obtain an IP address from a DHCP server then it will just use its own APIPA mechanism and obtain an address…
In other words, your Antenna does not get an address from your router…
