MikroTik wAP ac LTE6 kit - Is it possible to replace an R11e-LTE6 modem with an R11e-LTE?
Hello.
MikroTik wAP ac LTE6 kit - https://mikrotik.com/product/wap_ac_lte6_kit
Functionally and performance will not be affected?
Thx.
Solution: MikroTik wAP ac LTE kit (RBwAPGR-5HacD2HnD&R11e-LTE) - https://mikrotik.com/product/wap_ac_lte_kit
You can.
Remember that you think about doint change from Cat.6 to Cat.4 device then the performance means speed/stability will be worse.
You can buy RB without modem or/and modem itself or other modem.
