Hello everybody. Bought 4 wAP’s. Who tested them? It works as WISP AP but when I’m trying to connect them to Capsmann, they don’t work at all, devices cannot connect to SSID provided by Capsman, sometimes I see 2 SSIDs old (from WISP AP configuration) a the new one from Capsman. Then I tried to reset them, but after that I couldn’t connect at all! Reseted them from System/Reset, then tried to reset by pressing button - no effect! The same problems on 4 devices!
P.S. Updated them to 6.33 before configuration
I’m having the same problem. Have two cAPs that work great with my capsman. Tried using the wAP with it and now I cant find the wAP despite trying to reset (holding down the button for ~6 seconds when powering on). No wifi AP, no ethernet traffic. All LEDs indicate traffic though.
Stumped! Did I brick it somehow? Am I misreading the quickstart guide regarding reset procedures?
maybe check you are using wireless-cm2 package instead of wireless-fp
