Iam using mikrotik 5 rc 3 and iam getting prompt for entering username and password for webfig . but i cant know where the username and password can find
Thanks,
Sathish
Thanks,
Sathish
The default user is ‘admin’. Leave the password blank if you have not changed it yet.
The system users are kept in “/user”.
it was already configured router with the password it was a running server we are able to login to webbox and winbox but not webfig but , unfortunately the same credentials are not working
Sathish
Take a look at this post. Read the response from normis:
http://forum.mikrotik.com/t/webfig/36376/1
Its my fault its working , it didnt worked because the browser history problem
thanks for you time
Thanks,
Sathish
