Mikrotik Wifi and Wyze Cameras
I upgraded from a “hAP ac lite[952Ui-5ac2nD]” to a “hAP ac^2[RBD52G-5HacD2HnD]” both running v7.1 and region United States. The Wyze cameras refuse to connect to the newer ac^2 arm. I have gone all over the Wifi and WPA2 settings in both routers and both are identical. The Wyze camera just never registers nor can I see a log file entry that states its trying. My iphone and ipad work just fine on both routers. Any ideas?
yes.
  1. Send me all your terrible cameras
  2. Then buy better cameras
  3. Alternatively you can post your config because we dont have or know how to use crystal balls
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="united states" disabled=no frequency=auto mode=\
    ap-bridge ssid=mynet wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country="united states" disabled=no frequency=auto \
    mode=ap-bridge ssid=mynet wireless-protocol=802.11 wps-mode=disabled
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys supplicant-identity=MikroTik
Since you cannot follow simple advice
and decided that you know what he problem is by only showing a couple lines of the config,
there is no need for further assistance.
L8R
