Hope you will be fine. I have mantBox-2-12s 2.4Ghz. it has good throughput in every corner of my house.
But I’m to face two issues & problems with MikroTik Wifi.
WiFi is disconnecting after a few times on my laptop and on other devices like cell phones, tablets etc.(Maybe configuration issue)
When pinging from mantBox-2-12s 2.4Ghz to my Mikrotik router is very high. (I have MikroTik router & mantBox is directly connected wire distance=1 meter)
Come on. Your AP is 12dB too strong for the clients that must be able to answer. Wifi is bidirectional. Strong in one direction, weak in the other, is weak overall.
mantBox is in my room. but the result I have shared with you is weak overall. Please let me know what needs to do for better results and efficiency.
which Band need to use 20Mhz or 20/40Mhz eC or 20/40Mhz Ce which is best for multiple users.
WiFi is connected but some tine no internet on wifi…
