I have set up a Mikrotik peer in a Routerboard RB760iGS running the latest ROS (7.1) connecting to another peer (at home) which is also a RB760iGS running ROS (7.1).
The peer is defined in:
/interface wireguard peer
And the peer works once I have set it up. I am able to use my “road warrior” MikroTik and connect to home and web sites see me coming from my home address. Great!
But when I reboot my road warrior MikroTik, upon reboot, the peer does not “activate”. There are no handshakes and no traffic flows.
I can start the peer by either of these methods: 1) Edit the entry and change something, such as the keep alive or 2) Click on enable
Strangely, the peer is not “disabled” either. It is in a status somewhere in between. Only when I disable it, is when the entry is greyed out in Winbox.
So as a result, I have no internet access unless I got into the road warrior MikroTik and perform one of the 2 steps above. And then everything works.
What am I missing here? How can the peer be started/enabled on its own after a reboot? Right now it seems want to be ‘touched’ by a script or human.
One cannot tease with such a script and then not provide it. Do we have to beg, pray or pay for it? ))
Perhaps one should test your current setup with the script disabled, to ensure we have a consistent issue!
Took the easier road and checked the log of the device which is now sitting 105km away from home
Just did a reboot to be sure …
The issue is not there.
Netwatch properly logged status as being down at startup but after 10 seconds the interface came up without assistance.
And that was logged as well.
For archive purposes, this is a script you can use if you do have this problem (raw version which works for me. Could be fine tuned with proper search of ITF name etc etc)
Tool Netwatch
Host, ip address on other side of tunnel
Down script. Paste script from above
Time to check. Up to you. I would say 1 to 5 minutes. It should only run after a reboot.
You have a dns name (not just an ip address) in peer’s endpoint-address, right. This is still an issue, I have an open issue with SUP-62097.
Looks like the peer does not come up when the first resolve fails. If this happens again, please check if peer’s current-endpoint-address is empty.
Interesting inch worm that was an early question of mine somewhere in some thread somewhere that probably no one from MT read or ignored.
Firewall address list items at least for firewall rules seem to stay up to date. IS THERE TTL or some feature where it regularly checks?
I was wondering if so , if the router does something similar for WG associated rules where we use IP Cloud addresses…
The same issue. Only manual disable/enable peer on server help to resolve.
No connection even i do it after 110s after Mikrotik start via script. Only manual disable/enable peer… No DNS name on server configuration.
ROS 7.1rc3
Not sure what scripting you are referring to?
The scripts are to address when the client device is rebooted and the WG tunnel connection is attempted prior to the MYNETNAME resolving of the far end public IP.
I guess also for any interruption that may occur.
