Hello everyone!
I’m new one user of Mikrotik hardware, so please be lenient to my questions.
I have small local network in my house: central router RB2011UiAS-2HnD (1st port connected to WAN from provider, other ports are conneced via cable to local devices (most important - ether2 (TCL TV with Android TV) and ether5 (PC)).
I’ve bought private server for VPN and configurate WireGuard there. I’ve done configure where not all traffic run through VPN - only that one in adress list. It work well (with good speed), i need only add IP or domain into my adress list.
But I have a problem with runnig Netflix through my VPN. I read, it use dynamic system of changing IPs, so adress list doesn’t work. I try to do like here (https://buananetpbun.github.io/mikrotik/get-ip-address-list-netflix-with-raw.html - use dynamic determination of IPs), but it was happen some problems:
- VPN stop wiorking on my PC (but still working on mobile devices into my Wi-Fi network);
- TV don’t open Netflix app (mistake -12), but in this moment IPs added into dynamic list;
- Main connection speed drops up to very low value (CPU load near 80-85%).
So, I asked about your advises how to get it work (priority - TV device on ether2).
By the way I have question about speed of my connection. I have 300 Mbps from provider, but, for example in torrent tracker i have limit ~11 Mbps. Could you please give me some advises to my config?
# 2024-07-28 14:39:01 by RouterOS 7.15.2
# software id = **ELIDED**
# model = RB2011UiAS-2HnD
# serial number =
add name=bridge1-LAN port-cost-mode=short
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
disabled=no distance=indoors installation=outdoor max-station-count=50 \
mode=ap-bridge name="wlan1-2.4 GHz" ssid="**ELIDED**" wireless-protocol=\
802.11 wmm-support=enabled wps-mode=disabled
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether6 ] comment=ACUVOX
/interface wireguard
add listen-port=13231 name=wireguard1
add name=list1-WAN
add name=list2-LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik
add name=dhcp_pool1 ranges=192.168.168.21-192.168.168.199
add address-pool=dhcp_pool1 interface=bridge1-LAN lease-time=10m name=dhcp1
/ip smb users
/port
set 0 name=serial0
/routing table
add disabled=no fib name=wg
add bridge=bridge1-LAN interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge1-LAN interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge1-LAN interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge1-LAN interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge1-LAN interface=ether6 internal-path-cost=10 path-cost=10
add bridge=bridge1-LAN interface=ether7 internal-path-cost=10 path-cost=10
add bridge=bridge1-LAN interface=ether8 internal-path-cost=10 path-cost=10
add bridge=bridge1-LAN interface=ether9 internal-path-cost=10 path-cost=10
add bridge=bridge1-LAN interface=ether10 internal-path-cost=10 path-cost=10
add bridge=bridge1-LAN interface="wlan1-2.4 GHz" internal-path-cost=10 \
path-cost=10
set udp-timeout=10s
add interface=ether1-WAN list=list1-WAN
add interface=bridge1-LAN list=list2-LAN
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address= **ELIDED** endpoint-port=\
51820 interface=wireguard1 name=WereguardVPN preshared-key=\
"" public-key=\
add address=192.168.168.1/24 interface=bridge1-LAN network=192.168.168.0
add address=10.247.218.17/24 interface=ether1-WAN network=10.247.218.0
add address=10.10.10.5 interface=wireguard1 network=10.10.10.5
/ip dhcp-client
add default-route-distance=2 interface=ether1-WAN
/ip dhcp-server lease
add address= **ELIDED** server=dhcp1
add address=192.168.168.0/24 gateway=192.168.168.1
set allow-remote-requests=yes servers=\
10.240.8.2,77.241.17.2,1.1.1.1,10.10.10.5
/ip firewall address-list
add address= **VERY LONG LIST ELIDED**
add action=accept chain=input connection-state=established,related,untracked
add action=drop chain=input connection-state=invalid
add action=drop chain=input in-interface-list=!list2-LAN
add action=accept chain=forward out-interface-list=list1-WAN
add action=accept chain=forward ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward connection-state=\
established,related disabled=yes hw-offload=yes
add action=accept chain=forward connection-state=\
add action=drop chain=forward connection-nat-state=!dstnat connection-state=\
new in-interface=ether1-WAN
connection-mark=no-mark connection-state=established,related hw-offload=\
yes
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address-list=to-wg \
new-routing-mark=wg passthrough=yes
add action=mark-connection chain=prerouting connection-state=new \
dst-address-list=to-wg new-connection-mark=to-wg passthrough=yes
add action=mark-connection chain=prerouting comment=\
"Netflix by Heirro Networking" disabled=yes dst-address-list=to-wg \
new-connection-mark=to-wg passthrough=yes src-address-list=IP-Local
add action=mark-packet chain=forward connection-mark=NetflixConnection \
disabled=yes in-interface=wireguard1 new-packet-mark=NetflixDownload \
passthrough=yes
add action=masquerade chain=srcnat out-interface-list=list1-WAN
add action=dst-nat chain=dstnat **ELIDED** protocol=tcp \
src-address-list=admlist to-addresses=192.168.168.198 to-ports=80
add action=masquerade chain=srcnat out-interface=wireguard1 src-address=\
192.168.168.0/24 src-address-list=""
/ip firewall raw
add action=add-dst-to-address-list address-list=to-wg address-list-timeout=\
35w3d chain=prerouting comment="Netflix by Heirro Networking" content=\
netflix.com disabled=yes
35w3d chain=prerouting content=nflxso.net disabled=yes
35w3d chain=prerouting content=nflxext.com disabled=yes
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=10.247.218.1 \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wireguard1 \
routing-table=wg scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address= **ELIDED**/32 gateway=10.247.218.1 \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/system clock
set time-zone-name= **ELIDED**
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes
