Mikrotik Wireguard VPN ping/routing Problems
i am trying to route all traffic from a mikrotik to use the wireguard interface, I almost succeeded but I have some errors.
First I tried the server with a windows Wireguard Client and works lovely.
but with mikrotik I have some issues.
I managed to connect everything.
And it’s sorta working, I have ping, and the public IP is correct, but I have some timeouts on ping.
I suspect is some problem with the routing.
(I have firewall rules for UDP port and for LAN - LAN ips)
WIREGUARD SERVER
# 2024-12-27 00:18:56 by RouterOS 7.16.2
# software id = IT3J-YRBI
# model = RB750Gr3
add name=" LAN-bridge" port-cost-mode=short
add admin-mac=CC:2D:E0:CE:53:F4 auto-mac=no comment=defconf name=bridge \
add name="bridge mcast" port-cost-mode=short protocol-mode=none
set [ find default-name=ether1 ] mac-address=84:D8:1B:AB:B5:D5 name=\
    "ether1 WAN"
set [ find default-name=ether2 ] name="ether2 Lan Switch"
set [ find default-name=ether3 ] name="ether3 FFMPEG"
set [ find default-name=ether4 ] mac-address=4C:6F:BC:70:10:8F name=\
    "ether4 Mcast"
set [ find default-name=ether5 ] name="ether5 Encoder"
/interface wireguard
add listen-port=15121 mtu=1420 name=wireguard1_lan
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/ip smb users
/port
set 0 name=serial0
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=bridge comment=defconf ingress-filtering=no interface=\
    "ether2 Lan Switch" internal-path-cost=10 path-cost=10
add bridge="bridge mcast" comment=defconf ingress-filtering=no \
    interface="ether3 FFMPEG" internal-path-cost=10 path-cost=10
    interface="ether4 Mcast" internal-path-cost=10 path-cost=10
    interface="ether5 Encoder" internal-path-cost=10 path-cost=10
set udp-timeout=10s
/ipv6 settings
add comment=defconf interface="ether1 WAN" list=WAN
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-port=15121 interface=wireguard1_lan \
    name=peer7 persistent-keepalive=30s public-key=\
    "xxxxx_public_key_wireguard_client"
    name=win_PC persistent-keepalive=30s public-key=\
    "xxxxx_public_key_test_windows_pc_client"
add address=192.168.1.1/24 comment=defconf interface="ether2 Lan Switch" \
    network=192.168.1.0
add address=94.yy.xx.xxx/26 interface="ether1 WAN" network=94.xx.xx.xxx
add address=192.168.32.1/24 interface=wireguard1_lan network=192.168.32.0
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set servers=1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.1.1 name=router.lan type=A
    established,related,untracked disabled=yes
    invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
    protocol=icmp
    disabled=yes in-interface-list=!LAN
    disabled=yes ipsec-policy=in,ipsec
    disabled=yes ipsec-policy=out,ipsec
    connection-state=established,related disabled=yes hw-offload=yes
    connection-state=invalid disabled=yes
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new disabled=yes in-interface-list=WAN
add action=accept chain=input disabled=yes dst-address=94.yy.xx.xxx \
    dst-port=21 in-interface="ether1 WAN" log=yes log-prefix=testt port="" \
    protocol=tcp
add action=accept chain=forward dst-port=15121 in-interface="ether1 WAN" \
    protocol=udp
add action=accept chain=forward dst-address=192.168.20.0/24 dst-address-list=\
    "" src-address=192.168.1.0/24 src-address-list=""
add action=accept chain=forward dst-address=192.168.1.0/24 dst-address-list=\
    "" src-address=192.168.20.0/24 src-address-list=""
add action=dst-nat chain=dstnat dst-address=94.yy.xx.xxx dst-port=211 \
    protocol=tcp to-addresses=192.168.1.254 to-ports=21
add action=dst-nat chain=dstnat dst-address=94.yy.xx.xxx dst-port=990 \
    protocol=tcp to-addresses=192.168.1.254 to-ports=990
add action=dst-nat chain=dstnat dst-address=94.yy.xx.xxx dst-port=\
    50000-51000 protocol=tcp to-addresses=192.168.1.254 to-ports=50000-51000
add action=dst-nat chain=dstnat dst-address=94.yy.xx.xxx dst-port=7000 \
    protocol=tcp to-addresses=192.168.1.246 to-ports=7000
add action=dst-nat chain=dstnat dst-address=94.yy.xx.xxx dst-port=8787 \
    protocol=udp to-addresses=192.168.1.254 to-ports=8989
add action=dst-nat chain=dstnat dst-address=94.yy.xx.xxx dst-port=9595 \
    protocol=udp to-addresses=192.168.1.254 to-ports=9595
add action=dst-nat chain=dstnat dst-address=94.yy.xx.xxx dst-port=9696 \
    protocol=udp to-addresses=192.168.1.254 to-ports=9696
add action=dst-nat chain=dstnat dst-address=94.yy.xx.xxx dst-port=5555 \
    protocol=tcp to-addresses=192.168.1.254 to-ports=5555
add action=dst-nat chain=dstnat dst-address=94.yy.xx.xxx dst-port=8088 log=\
    yes log-prefix=8088 protocol=tcp to-addresses=192.168.1.254 to-ports=8088
add action=dst-nat chain=dstnat comment="" \
    dst-address=94.yy.xx.xxx dst-port=17788 log=yes port="" protocol=tcp \
    to-addresses=192.168.1.253 to-ports=80
add action=dst-nat chain=dstnat comment="" dst-address=\
    94.yy.xx.xxx dst-port=11101 log=yes log-prefix=emisie_vnc protocol=tcp \
    to-addresses=192.168.1.253 to-ports=5900
add action=dst-nat chain=dstnat comment="" dst-address=94.yy.xx.xxx \
    dst-port=11102 log-prefix=vmix_vnc protocol=tcp to-addresses=\
    192.168.1.254 to-ports=5900
    94.yy.xx.xxx dst-port=11103 log=yes log-prefix=vmix_vnc protocol=tcp \
    to-addresses=192.168.1.246 to-ports=5900
/ip ipsec profile
add disabled=no dst-address=0.0.0.0/0 gateway=94.yy.zz.zzz
add disabled=no distance=1 dst-address=192.168.20.0/24 gateway=wireguard1_lan \
    routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox port=XXXX
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/flash/pub
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=Europe/Bucharest
/system identity
set name=mikrotik
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
WIREGUARD CLIENT
# 2024-12-27 00:13:33 by RouterOS 7.16.2
# software id = ZRE7-477Q
# model = RB941-2nD
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] disabled=no mode=ap-bridge ssid=MikroTik \
    wireless-protocol=802.11
add name=WAN
add name=LAN
add name=pool1 ranges=192.168.20.10-192.168.20.254
add address-pool=pool1 interface=bridge1 name=server1
add bridge=bridge1 interface=wlan1
/ipv6 settings
set disable-ipv6=yes
add interface=wireguard1 list=WAN
add interface=ether1 list=WAN
add allowed-address=0.0.0.0/0 endpoint-address=94.yy.xx.xxx endpoint-port=\
    15121 interface=wireguard1 name=peer1 persistent-keepalive=30s \
    public-key="xxxxx_public_key_wireguard_server"
add address=192.168.20.1/24 interface=bridge1 network=192.168.20.0
add address=192.168.32.2/24 interface=wireguard1 network=192.168.32.0
add address=192.168.100.60/24 interface=ether1 network=192.168.100.0
/ip dhcp-client
add disabled=yes interface=ether1
add address=192.168.20.0/24 dns-server=192.168.20.1 gateway=192.168.20.1 \
    netmask=24
set servers=8.8.8.8,8.8.4.4
add action=accept chain=forward dst-address=192.168.20.0/24 src-address=\
    192.168.1.0/24
add action=accept chain=forward dst-address=192.168.1.0/24 src-address=\
    192.168.20.0/24
add action=accept chain=forward dst-port=15121 in-interface=ether1 protocol=\
    udp
add action=accept chain=input connection-state=established disabled=yes
add action=accept chain=input connection-state=related disabled=yes
add action=drop chain=input disabled=yes in-interface-list=!LAN
add action=masquerade chain=srcnat disabled=yes out-interface-list=WAN
add action=masquerade chain=srcnat out-interface=wireguard1
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.100.1 \
add disabled=no distance=1 dst-address=192.168.1.0/24 gateway=wireguard1 \
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wireguard1 \
/system clock
/system note
/tool mac-server
Post both configs full
/export file=anynameyouwish (minus router serial number, any public WANIP information, keys etc. )
posted
You should really prescribe to vlan filtering but will focus on other things for now.
  1. You have three bridges but only use two, so get rid of LAN-Bridge!
  2. The second MCAST bridge has no structure, IP address, pool etc…but will ignore that as well.
  3. You do not understand how wireguard works and what is the purpose of allowed IPs. Its to identify:
    a. external subnets local users want to reach, OR
    b. external subnets that are coming through the tunnel and landing at the local router.
  4. Attach address to bridge and not ether2, since you added ether2 to the bridge…
  5. Remove static dns setting.
  6. Forward chain firewall rules are not the place for port forwarding rules, those belong under NAT.
  7. why are all your firewall rules disabled…
  8. MISSING, input chain rule for wireguard hanshake.
  9. Added relay rule so you as admin can reach router B for config purposes after connecting to router A via wg.
  10. /interface list members incomplete
  11. Need to segregate client router users from remote ADMIN device coming on wireguard so only admin can access router.
    Thus use source address list to define admin and input chain modified.
# model = RB750Gr3
    "ether1 WAN"
    "ether4 Mcast"
/interface lte apn
/ip smb users
/port
set 0 name=serial0
/routing ospf area
set udp-timeout=10s
/ipv6 settings
add interface=wireguard1_lan list=LAN
add allowed-address=192.168.32.2/32,192.168.20.0/24  interface=wireguard1_lan name=MT Client Router  public-key="xxxxx"
add allowed-address=192.168.32.3/32  interface=wireguard1_lan name=PC Client1"  public-key="yyyyy"
add address=192.168.1.1/24 comment=defconf interface=bridge network=192.168.1.0
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
/ip firewall address-list    { use dhcp static leases where applicable }
add address=192.168.1.X  list=AUTHORIZED comment="local admin PC"
add address=192.168.1.Y  list=AUTHORIZED comment="local admin device #2"
add address=192.168.32.3 list=AUTHORIZED comment="remote admin wireguard laptop"
add address=192.168.32.A list=AUTHORIZED comment="remote admin wireguard smartphone/ipad"
    invalid
add action=accept chain=input comment="defconf: accept ICMP"  \
    protocol=icmp
add action=accept chain=input comment="wireguard handshake" dst-port=15121 protocol=udp
add action=accept chain=input comment="admin access"  src-address-list=AUTHORIZED
add action=accept chain=input comment="users to services"  in-interface-list=LAN dst-port=53 protocol=udp
add action=accept chain=input comment="users to services"  in-interface-list=LAN dst-port=53 protocol=tcp
add action=drop chain=input comment="Drop all else"    { install this rule last after above rules and firewall address list }
    connection-state=established,related  hw-offload=yes
add action=accept chain=forward comment="internet traffic"  in-interface-list-LAN out-interface-list=WAN
add action=accept chain=forward comment="wireguard to local LAN"  in-interface=wireguard1_lan  dst-address=192.168.1.0/24
add action=accept chain=forward comment="local LAN to remote LAN" out-interface=wireguard1_lan  src-address=192.168.1.0/24 dst-address=192.168.20.0/24
add action=accept chain=forward comment="wg remote relay"  in-interface=wireguard1_lan  out-interface=wireguard1_lan
add action=accept chain=forward comment="port forwarding"  connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else"
/ip ipsec profile
/ip service
/ip smb shares
/system clock
/system identity
set name=mikrotik
/system note
/tool mac-server
Router2
  1. No need to make wireguard a WAN list item as the other end is mikrotik and programmed to allow 192.168.20.0/24 traffic.
  2. Do not add netmask manually in dhcp-server settings
  3. For DNS set dhcp-server settings to wireguard of routerA, will also use dstnat rules to reinforce.
  4. MISSING, the part to force traffic to wireguard, a. table, b. routing rule c. modify existing route.
  5. Do not depend on ISp router for firewall rules…so many missing.
# model = RB941-2nD
add name=bridge1
/interface wireless
add name=WAN
add name=LAN
/ipv6 settings
/ip dhcp-client
add address=192.168.20.0/24 dns-server=192.168.32.1 gateway=192.168.20.1 \
add address=192.168.1.X  list=AUTHORIZED comment="remote admin PC from Router1"
add address=192.168.1.Y  list=AUTHORIZED comment="remote admin device #2 from Router1"
add address=192.168.20.Z list=AUTHORIZED comment="local admin device"
    invalid
    protocol=icmp
add action=accept chain=forward comment="wireguard to local LAN"  in-interface=wireguard1 dst-address=192.168.20.0/24
add action=accept chain=forward comment="local LAN to remote LAN or Router1 internet" out-interface=wireguard1  src-address=192.168.20.0/24
add action=masquerade chain=srcnat  out-interface-list=WAN
add chain=dstnat action=dst-nat in-interface-list=LAN dst-port=53 protocol=udp to-address=192.168.32.1
add chain=dstnat action=dst-nat in-interface-list=LAN dst-port=53 protocol=tcp to-address=192.168.32.1
/routing table
add fib name=use-WG
/routing rule
add action=lookup-only-in-table min-prefix=0  table=main
add action=lookup-only-in-table src-address=192.168.20.0/24 table=use-WG
add dst-address=0.0.0.0/0 gateway=192.168.100.1 routing-table=main
add dst-address=192.168.1.0/24 gateway=wireguard1 routing-table=main
add  dst-address=0.0.0.0/0 gateway=wireguard1 routing-table=use=WG
/system clock
/system note
/tool mac-server
Thank you for your reply.
I implemented the changes, I have some success.
edit
after restaring the peer ping is working and shares
but internet for devices still not working
also I added a TCP port on the server side for remote managing because the firewall filtering blocked me.
please if you have time to review the code
SERVER SIDE
# 2024-12-27 22:03:06 by RouterOS 7.16.2
# model = RB750Gr3
# serial number = 8xxxxx
    "ether1 WAN"
    "ether4 UPC Mcast"
/interface ovpn-client
add auth=null cipher=aes128-gcm connect-to=109.***.***.*** mac-address=\
    02:A0:F7:63:**:** mode=ethernet name=A********_ovpn user=b*****
/interface lte apn
/ip smb users
/port
set 0 name=serial0
/routing ospf area
    interface="ether4 UPC Mcast" internal-path-cost=10 path-cost=10
add bridge="bridge mcast" ingress-filtering=no interface=\
    A********_ovpn internal-path-cost=10 path-cost=10
set udp-timeout=10s
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
add allowed-address=192.168.32.2/32,192.168.20.0/24 endpoint-port=15121 \
    interface=wireguard1_lan name=peer7 persistent-keepalive=30s public-key=\
    "DP*****************************************"
add allowed-address=192.168.32.3/32,192.168.20.0/24 disabled=yes \
    endpoint-port=15121 interface=wireguard1_lan name=win_PC \
    "5n*******************************************"
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
    192.168.1.0
add address=94.***.***.***/26 interface="ether1 WAN" network=94.***.***.***
/ip dns static
    invalid
add action=accept chain=forward comment="wireguard handshake" dst-port=15121 \
    protocol=udp
add action=accept chain=input comment="users to services" dst-port=53 \
    in-interface-list=LAN protocol=udp
    in-interface-list=LAN protocol=tcp
add action=accept chain=input dst-port=X*** protocol=tcp
add action=accept chain=forward comment="internet traffic" in-interface-list=\
add action=accept chain=forward comment="wireguard to local LAN" dst-address=\
    192.168.1.0/24 in-interface=wireguard1_lan
add action=accept chain=forward comment="local LAN to remote LAN" \
    dst-address=192.168.20.0/24 out-interface=wireguard1_lan src-address=\
    192.168.1.0/24
add action=accept chain=forward comment="wg remote relay" in-interface=\
add action=accept chain=forward comment="port forwarding" \
add action=dst-nat chain=dstnat dst-address=94.***.***.*** dst-port=211 \
add action=dst-nat chain=dstnat dst-address=94.***.***.*** dst-port=990 \
add action=dst-nat chain=dstnat dst-address=94.***.***.*** dst-port=\
add action=dst-nat chain=dstnat dst-address=94.***.***.*** dst-port=7000 \
add action=dst-nat chain=dstnat dst-address=94.***.***.*** dst-port=8787 \
add action=dst-nat chain=dstnat dst-address=94.***.***.*** dst-port=9595 \
add action=dst-nat chain=dstnat dst-address=94.***.***.*** dst-port=9696 \
add action=dst-nat chain=dstnat dst-address=94.***.***.*** dst-port=5555 \
add action=dst-nat chain=dstnat dst-address=94.***.***.*** dst-port=8088 log=\
add action=dst-nat chain=dstnat comment="verificare PC" \
    dst-address=94.***.***.*** dst-port=17788 log=yes port="" protocol=tcp \
add action=dst-nat chain=dstnat comment="*" dst-address=\
    94.***.***.*** dst-port=11101 log=yes log-prefix=emisie_vnc protocol=tcp \
add action=dst-nat chain=dstnat comment="*" dst-address=94.***.***.*** \
    94.***.***.*** dst-port=11103 log=yes log-prefix=vmix_vnc protocol=tcp \
/ip ipsec profile
add disabled=no dst-address=0.0.0.0/0 gateway=94.***.***.***
/ip service
set winbox port=X***
/ip smb shares
/system clock
/system identity
set name=B*****
/system note
/tool mac-server
CLIENT_SIDE
# 2024-12-27 22:03:11 by RouterOS 7.16.2
# model = RB941-2nD
# serial number = H*********
add name=bridge1
/interface wireless
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
/routing table
add disabled=no fib name=use-WG
/ipv6 settings
/interface detect-internet
set detect-interface-list=all
add allowed-address=0.0.0.0/0 endpoint-address=94.***.***.*** endpoint-port=\
    public-key="PE*********************************************"
/ip dhcp-client
add address=192.168.1.254 comment="remote admin PC from Router1" list=\
    AUTHORIZED
add address=192.168.1.253 comment="remote admin device #2 from Router1" list=\
    AUTHORIZED
add address=192.168.32.3 comment="remote admin wireguard laptop" list=\
    AUTHORIZED
add address=192.168.32.4 comment="remote admin wireguard smartphone/ipad" \
    list=AUTHORIZED
add address=192.168.20.253 comment="local admin device" list=AUTHORIZED
add address=192.168.20.254 comment="local admin device" list=AUTHORIZED
add address=192.168.100.7 comment="MIHAI PC" list=AUTHORIZED
    invalid
add action=accept chain=forward comment="admin access" src-address-list=\
    AUTHORIZED
add action=accept chain=forward comment="wireguard to local LAN" \
add action=dst-nat chain=dstnat dst-port=53 in-interface-list=LAN protocol=\
    udp to-addresses=192.168.32.1
    tcp to-addresses=192.168.32.1
    routing-table=use-WG scope=30 suppress-hw-offload=no target-scope=10
/routing rule
add action=lookup-only-in-table disabled=no min-prefix=0 table=main
add action=lookup-only-in-table disabled=no src-address=192.168.20.0/24 \
    table=use-WG
/system clock
/system note
/tool mac-server
Main Router:
You have no LAN structure for bridgecast and thus I dont expect any traffic on ports 3,4,5.
Why do you keep putting full info on the wireguard settings??
PLUS THE ONE FOR THE DEVICE IS WRONG… the only source IP coming from the device is its wireguard IP address!!!
On the server side, endpoint port and persistent keep alive dont make any sense and should be removed.
add allowed-address=192.168.32.2/32,192.168.20.0/24 endpoint-port=15121 *
"DP
add allowed-address=192.168.32.3/32,192.168.20.0/24 endpoint-port=15121 interface=wireguard1_lan name=win_PC
“5n*******************************************”
You completely botched access to the router.
I gave you the clear way to do this… by firewall address list of authorized IPs…
Not sure why you ignored this so that is why you locked yourself out and created a different method which is completely unsafe.
Other Router:
Set this to none
I erred, my apologies, the rule for admin source address access in the input chain, I had forward chain instead.
add action=accept chain=input comment=“admin access” src-address-list=AUTHORIZED
There is actually an identical forward chain rule required.
As per my original post, there should be two rules not the one regarding wireguard traffic, and of course a third one being admin access.
add action=accept chain=forward comment=“remote subnet to local LAN” in-interface=wireguard1 dst-address=192.168.20.0/24 src-address=192.168.1.0/24
add action=accept chain=forward comment=“local LAN to remote LAN or Router1 internet” out-interface=wireguard1 src-address=192.168.20.0/24
add action=accept chain=forward comment=“admin access” src-address-list=AUTHORIZED
You may have a look at following site which demonstrated a successful configuration, which I use it daily without any problems.
Mainland China VPN Hong Kong via MikroTik and Wireguard
http://forum.mikrotik.com/t/mainland-china-vpn-hong-kong-via-mikrotik-and-wireguard/180468/1
thank you, simple straight to point worked first time! :smiley: , security and bla bla after .
Copying is not learning, but glad you have success.
