Mikrotik wireless N? - what product to use
  • I want to setup a Wirelress N network with Mikrotik products.
  • What wireless products from Mikrotik will let me do this / what is recommended?
Thanks for help,
Best regards,
Johan
R52Hn with mmcx to RP-SMA pigtail.
And then you can buy antenna that used RP-SMA connector (which is most linksys router use) A lot easier to source for RP-SMA antenna than other type of connector…
However, I have yet find a solution to securely lock the mmcx to RP-SMA pigtail on the case…the pigtail will just stick out of the case and connect to the anntenna
Maybe something like this?
http://www.titanwirelessonline.com/MMCX-to-RPSMA-Pigtail-p/pt-mmcx-rpsma.htm
I’m not recommending this vendor… it’s just the first one to turn up on a google search.
Also, RP-SMA may not be ideal… if your antennas have N connectors, you’ll want a NFB connector instead and a LMR-400 NM-to-NM jumper. There are SO many combinations out there it’s not even funny. Pick your router, radio, and antenna first. Then choose the appropriate pigtails and numbers to get everything connected.
