i’m tring to setup a RB952Ui with one Wifi 2,4 Ghz to connect to a access point, which is a internet router. The other Wifi 5Ghz for clients to connect.
The first Wifi has a DHCP client running and the second a DHCP server. This has worked so far.
With the script below it is possible to connect to the mikrotik using the client Wifi and it connects to the internet ap.
DHCP Server gives IP to clients but there is no connection to the internet. Internet is pingable within the mikrotik.
Probaly i did not understand the bridging between the two wireless networks.
So where did i mess up?
add name=bridgeLAN
add authentication-types=wpa2-psk eap-methods="" group-ciphers=tkip,aes-ccm mode=dynamic-keys name=profileLocal supplicant-identity="" unicast-ciphers=tkip,aes-ccm \
wpa2-pre-shared-key=###
add authentication-types=wpa2-psk eap-methods="" group-ciphers=tkip,aes-ccm mode=dynamic-keys name=profileRelay supplicant-identity="" unicast-ciphers=tkip,aes-ccm \
/interface wireless
set [ find default-name=wlan2 ] country=germany disabled=no installation=indoor mode=ap-bridge name=wlanLocal security-profile=profileLocal ssid=SID2
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=germany disabled=no installation=indoor name=wlanRelay security-profile=profileRelay skip-dfs-channels=all ssid=SID1
/ip hotspot profile
add name=poolLocal ranges=192.168.3.200-192.168.3.249
add address-pool=poolLocal disabled=no interface=bridgeLAN name=serverLocal
add bridge=bridgeLAN interface=ether2
add bridge=bridgeLAN interface=ether3
add bridge=bridgeLAN interface=ether4
add bridge=bridgeLAN interface=ether5
add bridge=bridgeLAN interface=wlanLocal
add address=192.168.3.1/24 interface=bridgeLAN network=192.168.3.0
/ip dhcp-client
add disabled=no interface=wlanRelay
add address=192.168.3.0/24 gateway=192.168.3.1
add action=accept chain=input
add action=accept chain=forward
add action=accept chain=output
add action=masquerade chain=srcnat out-interface=wlanRelay src-address=192.168.3.0/24
/system clock
/system identity
set name=RouterOS
