I want every request that comes in the port 80 is
redirected to port 3128 which is an external proxy.
Which rule should I use for this? Dstnat already tried but failed.
I need to make daily reports to the SARG and occurs parent proxy with the following situation: When I create reports appears only IP Mikrotik as it is who consults the proxy.
I want to make the hosts to query the proxy and not theMikrotik well as IP hosts appear in SARG reports. I tried to make the following rule
You need to adjust your layout. Move your Squid machine to another IP subnet such as 192.168.1.254. The redirect through the MikroTik should work after that.
