Mikrotik's WDS?
Hi, I want to use Mikrotik 433 and R52H on my access point side, and I want to use
Tp-Link TL-WA501G which uses Atheros chipset.
Now, are those tp-link AP’s available to connect 433 via WDS? Is that possible?
My other question is, I’ll use 2xR52H, what is the max. nr of WDS can be written to WDS list?
your tp-link should support wds, use the mac addresses of both wlan adapters and add them to you wds table.
